FS: HSR+Fuel Rails+Adj FPR+Valvecovers+Oil catchcan ALL POLISHED!
Up for sale is a Holley Stealth Ram Manifold (standard heads) with Anodized fuel rails and Adjustable Fuel pressure regulator, Polished Ball milled Valve covers with mounted MSD Blaster SS Coil, and a polished Catchcan With -An quick release. Manifold is Brand new, never ran, only mocked up. Manifold is PN: 7540P and Fuel rails are PN: 534-186.
Valve covers, coil, and catch can are used but still look/work awesome!
The manifold is based off of a tunnel ram carburetor manifold with a cast aluminum plenum which bolts to the top. This is a replacement for the GM TPI system. Or you can buy it as a complete stand alone EFI system if you are converting from carburetor.
This would be a great swap for a TPI'er or for someone to start off with a beautiful EFI setup.
The only reason I am selling is because this intake cannot be port matched to a 1206 intake gasket for my new heads. I am going with a Victor Jr and elbow from intakeelbows.com and will be buying welded VCs to match the elbow
If you have any questions, i can be reached at 918-605-5664. Lower pictures are with catchcan and Fuel rails mounted.
$800 Takes it all!!!
bigjay89gta
10-15-2015 08:04 AM
