370 LS1 (LQ9) forged motor, L92 race heads, T56 swap
Old 05-23-2008, 06:09 AM
camaroracerlt1's Avatar
Car: 1985 IROC Camaro
Hey, I have an unassembled 6.0L LS1 (engine from 02 Escalade) Motor has stock crank, all stock engine and valley covers, all engine mounted sensors and hardware, LS1 car waterpump with new 160 t-stat, new ported LS6 oil pump, new rollermaster double roller adjustable timing chain, new LS7 lifters, new canton baffled oil pan with pickup (LS1 style), new speed pro rod and main bearings, new dura-bond cam bearings, new Comp Cams Extreme Energy cam (.605/.609 lift, 287/289 dur. 112 lobe sep.), new Scat forged h-beam rods with upgrade ARP 2000 rod bolts, new Mahle Forged .030 over flat top pistons with -2cc valve reliefs with pins, and rings. Motor will need to be bored .030 over, balanced and assembled. $2800 +shipping
Also New L92 heads with new Patriot .660 lift double valve springs with locks and retainers, new Manely proflow undercut intake and exhaust valves, new offset rockers, used standard rockers, and new rocker stands. $1100 +shipped
or $3500 +shipping for everything, (I'll throw in the valve covers with coil packs and harnesses too) close enogh to pick up goes to the front of the line. If no one is interested in this stuff together I'll start parting it all seperate. In Painesville, OH. Send an e-mail to camaroracerlt1@yahoo.com for faster reply
I also have a complete T56 tranny from a 2000 Trans Am with Ram Power Grip HD clutch, flywheel, bellhousing, clutch hydraulics with adjustable master cyl., B&M shifter, and crossmember for this also if you are looking for a complete drivetrain. $1500 +shipping
Old 06-08-2008, 10:02 AM
THIRD GEN 92's Avatar
Car: 92 Camaro Rs Ls1 converted
Engine: Ls1 346
Transmission: t56
Axle/Gears: Moser/4:10's
Re: 370 LS1 (LQ9) forged motor, L92 race heads, T56 swap
p.m sent
Old 10-10-2008, 05:19 PM
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Im interested in the t56 if its still available, im only in michigan so its not too bad of a drive for me.
Old 01-30-2009, 11:33 AM
rxp1476's Avatar
Car: 84 Z28 H.O.
Engine: 305 H.O.
Transmission: 5 speed
Do you still have the t-56 set-up? I'm very interested. PM sent
Old 09-06-2011, 03:39 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Still available?
Old 09-06-2011, 10:05 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The post is 3 years old. The OP hasn't made a post since July of 2010. I'm willing to bet you won't get a response.
Old 09-07-2011, 02:06 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
1984HO
03-19-2021 11:59 AM
84z96L31vortec
08-20-2017 12:16 AM
theshackle
03-05-2017 06:37 PM
reiderz iroc
08-13-2015 04:57 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: 370 LS1 (LQ9) forged motor, L92 race heads, T56 swap
