GM Chevy SBC 350 CID Factory Forged Steel Crankshaft
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
GM Chevy BOP SBC Factory 350 CID Forged Steel Crankshaft. This crank has been Media Blasted, Magnafluxed, Turned .010/.010, and Balanced for 1800-1900 gram rotating assembly piston and rod. It is currently properly stored with cosmoline. All you would need to do to use this crank in for a 350 is clean it and blow it off real good with compressed air! 2 Piece Rear Seal. Stroke is 3.48" - with a standard 4.0" Bore = 350 CID. If you are .030 over bore would = 355 CID This crank is ready to go.
$400.
Thanks,
Dave
$400.
Thanks,
Dave
Mickeyruder
09-02-2015 02:45 PM
LT1Formula
08-20-2015 09:36 PM
