[CA] Lots of parts, stock TPI, misc performance parts
I have a bunch of stuff I;ve accumulated over the years and would like to get rid of.
#1 ZZZ Crate motor vacuum advance distributor, new, without cap. Asking 50 bucks plus shipping
#2 ZZZ Crate engine intake manifold, Winters casting, Aluminum GM replica of the 1970 LT-1 intake manifold, came on early GMPP crate engines. Asking 150 plus shipping. I'll throw in a once used Summit engine lift bracket that bolts to the intake and lets you hoist your motor.
#3 SOLDAccel 8.8mm Race Wires, New, part number 7065, http://www.summitracing.com/parts/AC...5&autoview=sku , Asking 75 plus shipping.
#4 Autometer Phantom A/F gauge, the a/f gauge is missing the black trim bezel, asking 20 for the a/f, plus shipping, I'll take 50 shipped for both. #5 Stock 89 TPI intake runners, with some dings and dents, nothing major at all. I'll take 40 shipped for these.
#6 Stock 89 TPI throttle body, has one top plate bolt busted off, and no IAC motor housing. 30 shipped.
#7 SOLD 4th gen ebony seat belts, set, all 4 complete, minus mounting hardware. Asking 150 shipped. Great condition
#8 Sold!!!ZZZ Crate engine harmonic balancer, heavy, 20 bucks plus actual shipping, it's new.
#9 Prothane poly front control arm bushings, new 45 shipped
#10 Stock front control arms, bushings and ball joints removed, except for one each, bit of a pain. I'll take 20 bucks for them plus actual shipping as they are heavy.
#11 SOLD 82-89 camaro reverse glow gauge set, 145mph speedo and 5K redline. Have not seen these in a while, bought a set on impulse and never used it. The letters and number light up a combination of red and blue, the faces themselves do not. Kinda cool, gives the cockpit a modern look. 40 bucks shipped, includes all wiring, switch/dimmer.
#12 82-89 camaro indiglo gauges, 145 speedo and 5k redline. Similar to the ones above, only the gauges themselves glow, can be switched between blue or light green. complete, new, never used, bought a backup set for my car and don't see them failing with how little I use them. Look great. 40 bucks shipped, includes all wiring, switch/dimmer.
#13 SOLD 730 ecm, no memcal. Bought this to convert over to speed density. Very good condition, comes with connectors and a few inches of wiring from the donor car. 50 plus shipping???
#14 Sold!!! - Comp Cams TPI Air Foil, VH041, like new, for stock TB, I don't know if they make this anymore. 20 bucks shipped???
#15 36mm Front hollow sway bar. Little overspray, otherwise no rust, clean CA part. Off my camaro, 40 bucks plus shipping? It's heavy.
#16 Rear PBR calipers, painted red, a bit faded now. no pads, the calipers were rebuilt a few thousand ago, then cleaned, then painted. Complete with carriers. I see these on ebay anywhere from 75 each to crazy amounts, these are good calipers, asking 150 for the set plus shipping.
That's about all I can think of right now. The prices are not set in stone. I will consider reasonable offers, but don't offer me 20 bucks for rear calipers of 5 bucks for poly bushings. If you think the prices are too high, then PM me with an offer. If you're not interested in buying anything, then please don't post. It's pretty simple. I'll throw pics into the next few posts
Will
Will
Re: Lots of parts, stock TPI, misc performance parts
few more, this oil pressure gauge did not fit my SBC, maybe it will fit your application, supposed to be a 1/8" thread npt, here's the summit take on it http://www.summitracing.com/parts/SMP-PS236/
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
What would i need to install the gauges you have i been wanting to have some on my car
Car: 1991 z28
Engine: 5.7l TPI
i would like the c arms and bushings... would you ship to Canada?
send me and email A.paine@rogers.com
I'll throw in the dual gauge pod/t-top pillar and both gauges if for 75 shipped. Everything you need, except vacuum line, that you will need to run from a manifold vacuum source into the cockpit. Let me know if that sounds fair. Thanks
Will
Will
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Do you got any pics of the pods and would you mind if i ask you how to install this since i never installed these things before
Install is really easy, just put the gauges in this pod, remove your pillar, install this pillar, and find power, ground, and 02 sensor signal for the a/f gauge, tap into dash lighting for the backlight on the vacuum gauge and run a vacuum line to it.
Will
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I'll take the ZZZ harmonic balancer. Please give me the shipping cost to 87108.
Car: 1987 firebird formula
Transmission: 5-speed
do you still have the airfoil? if you do I will buy it today.
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
pm sent about balancer
The passenger side Control arm have the bushings and Balljoints already removed?
is it straight not bent, etc?
Both arms have one remaining bushings each. I tried to remove them but they are really in there. The other bushing and the ball joint are out. The arms are in great shape, not bent, looking to sell as a pair. Thanks
Will
Will
anyway about the balancer, throw it in the smallest box that will fit it and ship it UPS ground cheapest rate and ill pay for the shipping cost plus the 20$ your asking for it... thanks
NBrehm
08-25-2015 11:49 PM
3rdgenparts
08-05-2015 11:57 PM
