Wilwood Dynalite Pro Series Front Brake Kit
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I have a used Wilwood Dynalite Pro Series Kit. I'm looking to get $500 + Shipping. These retail at $700 + Tax/Shipping.
This kit is made for cars over 2800+ pounds. Calipers are 4 piston, but appears to be an older design. The rotors are solid vented and have 0.81" thickness and slightly larger than OEM rotors. According to directions these will clear the 15" rims, but these also move the hub from OEM spec. This kit like most require you to modify your spindles, which is covered in the directions.
Alright I'm not here to mislead anyone so here's the rundown. I was told this kit was used for mockup, but the car never was mobile so no acutal run time on these. I did a quick inspection of this kit after I printed the directions/part list. The rotors look great, except for an area of surface rust where the caliper must have been resting. They should just rub off on use or could be cleaned up with sand paper before install. There are minor dings on some of the metal surfaces of the hubs, calipers, etc (probably from shipment). The pads look unused. I think it's missing one of the 16 nuts to attach the hub to the rotor, which can be replaced easily enough. One of the hub surface seals has a nick out of it and should be replaced to prevent dirt from getting into the bearing (able to buy it from Jegs or Summit through).
Pictures of the kit:
Like I said above looking to get $500 + Shipping. I've decided to just go with a C4 Kit instead. I'd also consider trading this for something of equal value.
Car: '91 Formula LS1
Engine: 04 GTO LS1, slp maf/k&n cai
Transmission: built 700r4, 3500/10" hughes
Axle/Gears: moser, 3.73, eaton posi
Re: Wilwood Dynalite Pro Series Front Brake Kit
I have a slightly used, full(complete) Edelbrock performer RPM, MPFI fuel inj. system for all sbc V8's(305-400) w/all the upgrades built on an alm. victor jr. mani. 28# inj. 1000cfm tb that I've been triing to sell for $1500 w/o any luck, this kit is worth almost $3k new & I only used it for 1 summer before I did my LS1 conv. no dents, digs or probs at all great system, works like new!
would you be willing to trade w/me for this? (I really need good brakes! & have been looking for some that fit my '91)
thanx
~Andrew
thanx
~Andrew
Engine: 383 SBC
PM sent for more details.
Engine: 383 SBC
Still for Sale.
Car: 1991 firebird formula convertible
Engine: 377 Small block
Transmission: 700R4 Done up
I'd be interested in these however I'd need to figure out if they would fit my rims, they are ruff racing R281 rims at 18X9.5 with a 1.75in spacer, these rims are real deep dish and the wheel spokes go pretty deep in the rim, I know these don't fit the C5 brakes, do you know if they would fit?
Engine: 383 SBC
No clue. For now this item is no longer for sale. I'm now determined this isn't even a WilWood Kit. Guy that sold me this kit obviously didn't know or lied.
These are 12"+ rotors and 1.25" thickness. I assume this might be an old JFZ kit. I might use them eventually.
hectre13
12-11-2023 08:14 AM
Terrell351
06-13-2021 01:13 PM
red90IROCls1
08-25-2015 06:56 AM
