[PA] Full MN6 T56 swap, Pro 5.0 shifter, Spec Stage 3 clutch, Spec Billet Steel Flywheel
I swapped in this MN6 T56 2 years ago - bought it off of a forum member that had it listed on eBay. At the same time I installed the Pro 5.0 shifter, Spec Stage 3 clutch, and the Spec Billet steel flywheel. Will also fit Third Gens.
I'd like to sell everything as a package as this would be perfect for someone looking to do this swap. The transmission runs flawlessly and had about 65,000 miles on it when I purchased it (information from previous seller, I cannot confirm or deny that).
I only put 2,500 miles on the car with this setup, so the shifter, flywheel, and clutch are all but brand new. The clutch was carefully broken in, per Spec's and LS1tech user's instructions for almost 700 miles. GREAT street manners and grabs hard when you want it to.
I've decided to go with a TH400 and a transbrake as I make the car a track car. I have almost $3,000 into this setup and would love to sell it to someone on the boards who's looking for a great way to spice up their ride and toss in a 6-speed.
Everything is still in the car and will be removed the weekend of June 18th, crated up and be ready to ship the following Monday.
Local pickup is obviously ideal - Everything located in West Chester, PA.
Asking $2,500 OBO for the whole setup, buyer to split actual shipping costs. If there's no interest by then, I will sell the shifter, clutch, and flywheel separately, keeping the swap intact without those pieces.
Car: '89 Formula
Engine: 355 SBC, AFR 195s
Transmission: T-56 Swap
Axle/Gears: 7.5 Eaton LSD w 4.10s
Re: Full MN6 T56 swap, Pro 5.0 shifter, Spec Stage 3 clutch, Spec Billet Steel Flywhe
now, by "full" swap, would you also be including things like the pedal assembly, master and slave cylinder, etc? I want to do a auto to T56 swap, but need everything to do it.
That is correct. Pedals, master and slave, etc is all included.
