[FL] aeromotive S/S fuel pump and carter fuel pump cheap! fuel cell and regualtors too
selling my aeromotive S/S fuel pump with 3/8 npt to -10 fitting on it. works great just upgrading to a Aerospace ultra comp 400. the aeromotive fuel pump is good for up to 700 hp. 5-10 psi i believe it what it runs.
85 shipped
Selling my carter fuel pump which is self regulated at 8.5 psi. Its good for up to 500hp and also works great,. It was used as my fuel pump for my nitrous system..
45 shipped.
1 gallon fuel cell with the foam inside of it to prevent slosh. comes with barb fittings for 3/8 fuel line
40 shipped.
Also selling a aeromotive fuel pressure regulator that was used with my carter fuel pump for nitrous. it has 3/8 barb fittings on it as well right now.
30 shipped for that
85 shipped
45 shipped.
40 shipped.
30 shipped for that
Re: aeromotive S/S fuel pump and carter fuel pump cheap! fuel cell and regualtors too
So the regulator is for low pressure setting? What is the range? I could use it if it is adjustable up into the 60# range.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i have the same unit... you need a different spring inside the regulator to use it from 20-65 psi...... idk where you can buy that spring because it came with both springs when you buy it new...
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I have several 13301's I have bought from forum members that only came with one spring
( seller had lost the other)
Have tried to find the other one but Aeromotive don't list the spring as a seperate item ;
all they have listed is the replacement diaphragm
AkDrifted
08-17-2015 07:45 PM
mcquigg
08-13-2015 02:26 PM
