wilwood brake set up 6 piston front 4 piston rear 13 1/2 rotors
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
i have a complete custom wilwood brake set up to run 6 piston calipers front and 4 piston calipers rear with 13 1/2 cross drilled and slotted rotors front and rear, stainless steel brake hoses also, kit was put on car it was moved around but no fluid was ever in them asking $2400 for all parts kit was $4300 new,
Transmission: auto
Re: wilwood brake set up 6 piston front 4 piston rear 13 1/2 rotors
rear pics
Transmission: auto
you could do 17 depending on the way the inside is made but i had 18 just to be safe it had plenty of clearance,
also price is negotiable, project car is long gone and really don't have plans for another one like that way over the top
Transmission: auto
still have make offer looking to sell
Transmission: auto
Tibo, yes they are super light, all brackets and bolts, were on a 10 bolt but look like they will fit a 9 bolt also
Transmission: auto
price drop asking $2000
Transmission: auto
08753
1 Post
Car: Too many cars
Any mods needed to make the front & rear work? Im assuming they are not direct bolt ons...
Transmission: auto
i dont remember having to do anything special, think it was bolt on
Car: 1988 Iroc Z28
you gonna put em on my tab ? i'll get with you this weekend on those wheels .been a hectic few weeks
Transmission: auto
any interest at all
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
any chance these will fit '91T/A cross lace rims? 16 inch factory.
thx
thx
Transmission: auto
strc09, that kind bites for me,
palric, i dont think so the rotor is almost as big as the inside of a 16 inch rim with no caliper on it.
Transmission: auto
still have complete set up
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
I have interest just no money so not for me but hope you sell it soon.
Transmission: auto
back up to top, very surprised i still have these
Any idea if these will fit a '92 Vette?
I am out of 3rd gens, am working on a Vette resto. This could be a cool upgrade.
Transmission: auto
i have no idea.
Car: 1988 firebird formula
Engine: 383 forged stroker
Axle/Gears: Currie Ford 9
I have rear drums on my car do these come with brackets to bolt up to my rear
Transmission: auto
yes and they are in the second post with pics
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
No proportioning valve? assuming it might need them?
Transmission: auto
not needed, uses stock one,
Car: RS Camaro
Would you only need a porporting valve if it was a drum rear end swapping to a disc break rear end? Thats what my buddy had to do for that..
An adjustable proportioning valve would serve you best for anything except a complete factory system. This member's setup uses the same size rotors front and rear just different calipers. The calipers that this setup uses are awesome and the rears would need to be dialed down in line pressure to keep the rears from locking up prematurely. These cars even with stock 4 wheel disc had smaller rear rotors and these are all 4 the same size so as you can tell now any stock proportioning valve would be a mismatch and would only work for "light" braking.
Transmission: auto
they are both correct, if you have rear drums you would need a disc rear prop valve, if going race route you would need adjustable one, for my application i was building a street friday night and nice weather show car, i wanted holy crap factor not race factor
Transmission: auto
like what?
Will these change my dimensions on how my wheels fit in the fender wells such as change the offset of how far they sit in or out. Because my wheels are right by the outer fender well lip now and I have no room to spare for added width to the axles. I have disc up front and rear drums now.
Transmission: auto
they were ordered for a third gen and it was a 91 z28 with drum rear, i was going to run 17 inch rims, as far as it goes i cant help with anything else
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
