[Sold] Procharger P1SC supercharger kit
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I'm toying with the idea of selling this. For the right money, I would let it go and start a new direction. I have the following. This is a thirdgen kit for serpentine bracket cars.
Updated list, found a few more things in the box:
P1SC Polished head unit, little use
Mounting bracket with hardware
Tensioner assembly
Crank pulley
Crank shim(s)
3.70 Supercharger pulley
3.40 Supercharger pulley
4.25 Supercharger pulley
Procharger INLINE fuel pump with lines
Procharger EFI fuel pressure regulator
Procharger BOV/bypass valve
Belts
New Procharger lube
Air filter
So what else do you need? Well I somewhat expect you to know if you are looking for this. You will obviously need to plumb the head unit into your trottle body or carb.
For port EFI (TPI) the FPR and INLINE PUMP will provide your fuel under boost.
You will need to either lock in timing or get a BTM, code $59, or some other method.
An intercooler wouldn't be a terrible idea either.
If you have a blow-through carb you could get away with a couple of feet of 3" tubing and a carb 'hat', lock your timing in at 24 degrees and make 600 HP.
I'm thinking about $2,250 plus shipping. Not really interested in trades unless it was a sportster or a convertible.
-- Joe
Tensioner assembly
Crank pulley
Crank shim(s)
Belts
New Procharger lube
Air filter
-- Joe
1 Post
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: Procharger P1SC supercharger kit
LSx parts? I have a 2011 LC9 5.3 shortblock w/15K miles and have cash?
Just throwing it out there!
I'm toying with the idea of selling this. For the right money, I would let it go and start a new direction. I have the following. This is a thirdgen kit for serpentine bracket cars:
Tensioner assembly
Crank pulley
Crank shim(s)
At least two, but I think three supercharger pulleys
Procharger BOV valve
Belts
New Procharger lube
Air filter
So what else do you need? Well I somewhat expect you to know if you are looking for this. You will obviously need to plumb the head unit into your trottle body or carb. You will need a way to provide fuel under boost, and a way to control timing. An intercooler wouldn't be a terrible idea either. If you have a blow-through carb you could get away with a couple of feat of 3" tubing and a carb 'hat', lock your timing in at 24 degrees and make 600 HP.
I'm thinking about $2,100 plus shipping. Not really interested in trades unless it was a sportster or a convertible.
-- Joe
Tensioner assembly
Crank pulley
Crank shim(s)
Belts
New Procharger lube
Air filter
-- Joe
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Still available? I am interested. Putting serious thought towards going blow-thru with meth on my 355. Shooting for 600RWHP and I think the P1 can get me there.
1 Post
Car: 1987 GTA
Engine: 383 HSR Procharged
Transmission: TKO600
Axle/Gears: Moser 9", 35 spline Wavetrac 3.89's
Joe,
I emailed you a few times. Please give me a call today about the kit..Sold you a muffler recently if you remember..
Thanks,
Chris
330-204-4199
Thanks,
Chris
330-204-4199
Hi Guys,
Chris did email me. I've been slow to respond since an injury this past week, and right now I'm dealing with wind damage and no power. (running the house on generator).
I do have the kit available. I have been offered $2,000 locally. I think it's worth more than my asking price, so as of right now I'm holding out for my asking price. It's still on the car and runs great, so I'm not in a rush to sell it. I may even keep it, so I won't get beaten up on the price. If I get what I want for it, I'll just try another setup.
-- Joe
-- Joe
1 Post
Car: 1987 GTA
Call me..Hope you all are ok up there. I have friends up that way and they told me the same thing..Take care.
Chris (sparks454) paid me for this late last night, so it's sold. shipping out Monday!
-- Joe
-- Joe
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
