SBC 383, AFR 195cc heads, GM847 cam, TCI EZ TCU, EBL, Edge Converter 4L80e
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Ok guys/gals, I have a lot of parts that is for sale. I'll update the list as I have it ready. I would prefer local sales but if the buyer wishes, I will ship at buyers expense. Buyer pays for all Paypal fees as well.
Going to split the Engine up....so here we go:
1)
A) 383 SBC engine. 11:1 compression Probe Forged pistons with 64cc heads, Eagle crank and rods, Total Seal piston rings, ARP rod and main cap bolts. B&B 6 qt oil pan with crank scrapper and windage tray. Also comes with SFI flexplate and balancer. External balanced rotating assembly. Block is a 638 with factory hyd roller bosses. 1 piece rear main seal and bored .030 over and decked down to 9.008 from 9.025 - $1300 (SOLD)
B) AFR 195cc heads 65cc combustion chamber, straight plug #1034. ARP 12 pt Head bolts, guideplates, and AFR 8019 .650 lift springs - $1100 (SOLD)
C) 1.6 Comp Gold non-self aligning rockers for 3/8" studs less than 1k miles on them, would sale 3/8" ARP studs for an extra $25 - $200 or $225 with studs(SOLD)
D) Crane 234/242 cam with .538/.559 on a 112LSA - $200 (Sold)
E) Roller Lifters and Spider Gear - $65(SOLD)
F) Cloyes double roller timing chain - $20 (SOLD)
G) GM Performance tall valve covers powdercoated gloss black with polished machine lettering - $300 (SOLD)
H) Lokar dipstick for passenger side of block - $30 (SOLD)
2) Edelbrock Victor Jr. MPFI intake with fuel rails port matched to the AFR 195cc - $300 (SOLD)
3) Accel 1550 cfm Throttle body - $300 (Comes with a 2" spacer).....SOLD!
4) no longer for sale
5) Extreme velocity hat - $150 (comes with 1.5" spacer for throttle linkage clearance) - SOLD
6) No longer for sale
7) TCI EZ-TCU for 4L80e, 4L60e, 4L65e, etc. - $450....SOLD!
8) Procharger bracket with spring tensioner upgrade (will come with all bolts including the manual tensioner, crank pulley, all belts I have and two pulleys (4.00 and 4.25). Bracket new is a little over $500 without all the belts, pulleys, etc. Asking $550 (I'll throw in an ARP dampener bolt as well with it). Without pulleys, I'll sell for $450. (SOLD)
9) PowderCoated Serpentine belt system (Metal silver was the color), comes with alternator (145amp), water pump with pulley and stainless steel bolts, SMOG pump pulley delete, brand new Goodyear Gatorback belt will be included - $300 (Can add crank pulley if needed) (SOLD!)
10) EBL Computer P4 (not even a year old) - $375 (comes with CD, wiring, etc)....SOLD!
11) Crane HI-6S ignition with PS-91 coil - $125 (SOLD!)
12) Stock Distributor with 369 module - $50
12) Stock distributor with no module - $30
1)
Re: SBC 383, AFR 195cc heads, GM847 cam, TCI EZ TCU, EBL, Edge Converter 4L80e
Pics of ignition system to martinez1114z28@gmail.com thanks
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
How much would you take for those heads?
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
$1100 and I'll throw in the ARP bolts as well if you want them.
Would you please send pictures of the intake, throttle body, and injectors to hutchenc@gmail.com when you get a chance?
Also, do you know what gasket size the intake is matched to? I'm running AFR 220's so I'm assuming it's way smaller?!
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Ill be second in line for the heads if they are cnc 1205
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
All PMs replied and pictures sent to all you wanted some.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
send pic of the throttle body? or attach it to this post?
Is the bar across that throttle body (which has the stud mount for the air cleaner) a part from Accel or is it custom? Just looks a bit odd.
Ah I see...so, really stupid question here, how does one put a regular air cleaner on it? Did Accel include anything with it to mount the lid?
Engine: 4++,350 & 305 CIs
Been looking for that throttle body for a long time and now I'm not ready to buy it.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I'll make someone a package deal on the Procharger bracket and powdercoated serpentine system as well.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Intake is sold
Procharger bracket is sold.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Serpentine belt system, Comp Gold rockers, and Extreme velocity hat is left.
Also got a mini-torque starter as well.
Car: 1987 Camaro IROC-Z
Axle/Gears: 4.11 Strange 12-Bolt
does the serpentine system come with the A/C and smog bracket as well? or just the alternator/power steering bracket?
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Comes with both brackets, 145 amp alternator with pulley, water pump, smog delete pulley, SS bolts for water pump pulley, water pump pulley, crank pulley, tensioner, and belt. No A/C.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Valve covers are marked sold.
Anymore pics of the serp setup?
How many miles on it?
All I would need to install is the a/c compressor or delete pulley?
Shipping quote to 11355 please.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I'll send you some pics of it.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
I'll resend them to you again tonight.
Thanks!
Thanks!
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Updated parts and bolded parts still available.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Serpentine belt system has sold.
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Distributors still for sale.
evilstuie
01-09-2020 08:29 PM
