[CA] Tremec T56 retrofit complete kit
Car: 68,87,99 maros, 07 tbss
Engine: TPI,LS2,LSA,L92
Transmission: T56,T56,T56, 4L80E
Axle/Gears: 12bolts and 14 bolt lol
Decided on switching up my build. I have a T56 Tremec reotrofit trans that was rebuilt and upgraded internals(built and installed by DynoDon). Has the bell housing, trans, hydraulics, McLeod Clutch, steeda shifter(best shifter I've ever used), correct aluminum driveshaft(3.5" or 4"). From what I recall this places shifter in stock T5 location and allows the use of the stock speedo cable. Complete setup has approx 1000-1500 miles. Asking $2500 OBO for everything mentioned. Trans is located in So-Cal but can be shipped.
Re: Tremec T56 retrofit complete kit
Trans is still on vehicle. I'll be pulling the engine out in the next week or so. As far as upgrades from what I recall parts were sent out for some treatment to harden the parts. Along with a full performance rebuild. Has the 2.97:1 first gear ratio.
Bump open to offers. Also willing to trade for a 12 bolt, 9", dana 44 or 60.
1 Post
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
What additional parts would be required to use this unit to replace a T700 behing a L98 350 SBC?
clutch & pressure plate bolts
pilot bearing
crossmember (fab one)
PROM for the ECM
pedals and neutral safety switch
NSSwitch connector and wiring
floor sealing boot
shifter trim boot and console trim
reverse light connector and wiring
That's nearly it.
Modified factory one. I can include it in the package deal.
Everything on the list above except you're getting the flywheel, clutch assembly and all the hardware with it. Also I can include the trans crossmber. I'm sure I can find a new pilot bearing and include it.
Sorry forgot to update. Sold last week
Terrell351
06-13-2021 01:13 PM
toronto formula
11-10-2015 06:17 AM
Mickeyruder
09-02-2015 02:45 PM
