[IL] TPIS BigMouth, SLP Semi-Siamesed Runners, SLP Dif Cover, FIC 24lb Inj, NOS, Pro 5.0
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
(PICS BELOW)
TPIS BigMouth Intake Manifold w/ New Installation Parts Kit
Like New. Purchased from TPIS with only their dyno time on it. Unmolested and Unported. Unavailable from TPIS or anywhere now and hard to find. $450
SLP Runners - Semi-Siamesed Early Style. Polished. Super Rare.
Never Installed. Original Style SLP RPO option. One batch of runners per side are cast completely hollowed. Orig SLP TPI Gaskets, RPO Manual Supplement and SLP Performance Pack Underhood Decal unpunched. Polish could use touch up.
SOLD!
24lb Injectors from FIC (Fuel Injection Connection)
New, never installed. Flow matched by FIC. Part # F1TE-D5A SOLD
Polished TPI Plenum 91-92 Speed Density Style w/ rare Accel short alum distributor cover replacement, also polished.
Won't sell cover separate.
Needs more polishing work but the hard part is done already. SOLD
Pro 5.0 Short Shifter for 82-92 T5 Transmission
Less than 3k miles. Mint. Needs 2 bolts that attach the stick, can't find them. Stick was never used. $150
SLP / AMM Differential Cooling Cover
Take off from SLP's Camaro SS 4thgen. Never saw the street.
Like New. $90
Cold Start Delete Plug - Billet Alum. by Custom Billet Works
New, never installed. $25
Fuel Pressure Gauge for TPI Fuel Rail by HyperTech
Like new. Stored with a cap to prevent contamination.
Part Number: 533-4004 $40
Nitrous Oxide Systems (NOS) Remote On/Off Solenoid
Used briefly - NOS Part # 16058 $150
Nitrous Oxide Systems (NOS) Purge Valve
Used briefly. NOS Part # 16030
$55
Nitrous/Fuel Nozzle - NOS identical copy.
Not sure of maker. - Never used. No jets
$40
Spark Plug Heat Shield Boots - DEI
Used, slightly dirty but can be painted w high temp paint no prob.
*Note: they won't fit over the big boot 8.5" MSD wires unless you're crimping your own boots.
$30
Energy Suspension Polyurethane Greasable Sway Bar Set. Zinc Coated Part # 9.5167G 1-5/16" - New in box $15
Seat Belt Buckles Receivers Front, Black
No cracks or wear where they usually wear out and the plastic breaks. Buttons work fine. SOLD
Paypal only. PM any questions. No trades unless you have a T-Ram for sale. Thanks.
SOLD!
Like New. $90
$55
$40
$30
Car: 91RS_92Z28
Engine: 5.0_5.7
Re: TPIS BigMouth, SLP Semi-Siamesed Runners, SLP Dif Cover, FIC 24lb Inj, NOS, Pro 5
Engine: 4++,350 & 305 CIs
May be interested in the SLP diff cover.
Also interested in where the runners went! (hate getting old)
Car: 91RS_92Z28
Engine: 5.0_5.7
Here are the SOLD Semi-siamesed SLP runners. They went to a good home, a mod here.
Ah, I know who has them now. Good home.
Car: 91RS_92Z28
Engine: 5.0_5.7
List Updated.
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
Price on diff cover shipped to 95363
Car: 91RS_92Z28
Engine: 5.0_5.7
BigMouth Pending. You're next inline if it doesn't work out.
Transmission: Pro-built 700R4
PM sent for sway bar bushings.
Still waiting on reply.
