[FL] Ram 2555 aluminum flywheel for sale
Selling a brand new never mounted Ram 2555 aluminum fly wheel. This fly wheel is to use a t56 on a SBC with a 2 peice rear main seal. The reason for sale is the build has gone in a diferent direction trans wise. Asking 350 plus shipping
Car: '87 Z-28
Engine: LT1-topped 400
Re: Ram 2555 aluminum flywheel for sale
Hey, I just recently dealt with this same issue, installed this flywheel onto my externally balanced 400. There isn't a balance kit available, but you can use a balancing plate which is sandwiched between the crank and flywheel - one of these guys is what I ended up with, had to bend it over a bit to not hit the lip of the flywheel. There is an offset style available, but it didn't fit over the flange on my crankshaft so don't get one.
I put a weight plate ( 0.100" thick on a 400 with the basic Spec 2pc. seal LT1 T56 flywheel. It prevented clutch release. There are a few ways to compensate for this. But the Valeo design has a narrow window of clutch travel.
And the starter gear ring was chewed at the teeth, offset.
