[PA] GM Performance parts ZZ4 350 for sale price lowered
I have a ZZ4 350 crate motor for sale. It is currently in an 87 Trans Am I bought for parts. It has approximately 25,000 miles according to previous owner. It has new E3 spark plugs and fresh oil change with Brad Penn 10w30 semi synthetic oil. Motor runs great. Carb needs to be tweaked. Runs slightly on rich side. Motor currently has an Edelbrock 600 cfm carb on it. Motor has a new water pump, alternator .
Can hear run and drive for next week or so before I pull the motor. I also have 3 videos of it running and driving.
$1950 b/o for the motor
Here are the specs:
These Chevrolet Performance ZZ4 350 C.I.D. 355 hp turn key crate engines include all of the necessary parts to get your engine running. With over 405 ft.-lbs. of torque, the ZZ4s are the best way to put an aluminum head, 4-bolt main block, roller cam, high performance small block between your favorite fenders. The aluminum angle-plug cylinder heads have screw-in rocker studs, 1.94 in. intake and 1.50 in. exhaust valves, and 58cc combustion chambers that yield a crisp and responsive 10:1 compression ratio. Also included are lightweight valve spring retainers, radiused valve seats, and valve stem seals to help keep the oil where it belongs. To complement the cylinder head design, we've incorporated a billet steel hydraulic roller tappet camshaft with a .474 in. intake and .510 in. exhaust valve lift. The combination makes 355 hp at 5,250 rpm and has that great-sounding musclecar idle, with just enough lope to let people know that these are no station wagon engines.
Here are the specs:
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Re: GM Performance parts ZZ4 350 for sale
Found that you're too far away in one of your old posts. Bummer. GLWS
Engine: 4++,350 & 305 CIs
Location? Picture of the block where the VIN would normally be stamped? It should have "ZZ4" stamped there. (may be hard to get with the alt over the top of the area)
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Re: GM Performance parts ZZ4 350 for sale price lowered
If you were closer, this would be on an engine stand in my garage this weekend. I know we've done business before. Good seller guys - don't pass this deal up.
Bump to keep it up top.
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Does it come complete with the accessory drive, alternator, HEI, etc? I would be looking to swap it into an older Buick, so I would basically need everything down to the motor mounts.
