[CT] TPI parts and more
Old 06-03-2017, 05:55 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Transmission: Dynamic Racing Reverse Manual 700r4
Axle/Gears: 9 Bolt 3.45
TPI parts and more
Hey guys, I've spent the last year trying to get the 305TPI running as best as I could in my car. after spending all the money and still not being happy with the car I decided to finally pull the engine and put in a carbed 383 which is what I've wanted since I bought the car.
The majority of these parts have zero miles on them, I haven't driven the car since last june. I've only started and idled the car with them about 25 times max. I have receipts for the majority of this stuff to prove how new they are. I have all the bolts for pretty much every part, I can also remove the paint if you prefer. I will split any of the parts up except for the injectors.
I'm also open to trades if you have anything to help my carb'd 383 swap
-brand new coil inside (zero miles)<br/>-dizzy cap is a few years old (about 4000 miles)
-Egr was put on in 2014 (about 4000 miles)<br/>-New egr temp switch put on in 2015 (about 60 miles max)
-fuel rail has all brand new o rings (zero miles)<br/>-FPR has a rebuild kit in it (zero miles)
-southbay Bosch D3 injectors brand new (zero miles)
-TPI intake manifold, obviously has 30 years of use, I'll clean it at work in the parts washer before shipping
-Throttle body and plenum are in good working order<br/>-TPS and IAC are from autozone and were put on in 2013-2014, they work fine (about 4000 miles)
Last edited by TylerSteez; 06-03-2017 at 06:01 PM. Reason: adding info about trades and what comes with the parts.
Old 06-03-2017, 05:57 PM
TylerSteez's Avatar
Engine: 383 stroker
Re: TPI parts and more
-Maf is a new re manufactured one from carquest, may have drove the car around the block with it on once.
runners with 9th injector provision, I have a block off plate for the 9th injector as well that ill throw in with them, I can take the paint off if you prefer
Old 06-05-2017, 06:14 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
prices on egr and fuel rail?
Old 06-05-2017, 06:40 PM
TylerSteez's Avatar
Engine: 383 stroker
Egr without the temp sensor wire is $25
fuel rail is $25
Old 06-11-2017, 08:11 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
fuel rail is $25
ok im interested just have to do a bit more diagnostic
Old 06-11-2017, 07:52 PM
2012sergen11's Avatar
Car: 1987 Trans Am
Interested in a price on the injectors and the egr if tylercamaro doesn't take it
Old 06-11-2017, 08:00 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
have at it sir, im just gonna delete mine
Old 06-11-2017, 08:15 PM
TylerSteez's Avatar
Engine: 383 stroker
the egr and temp sensor are possibly sold. how does $105 sound for the injectors? they're 19lb bosch d3's
Old 06-14-2017, 10:47 AM
Car: 1987 Trans Am
PM sent
Old 06-14-2017, 11:35 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
How much for the plenum and TB. and also would you separate? I am really just looking for a plenum but if the price is right I would take both.
Old 06-14-2017, 03:52 PM
The Eager Teen's Avatar
Car: 1985 Trans Am
Engine: 1990 Corvette L98 w/ ported 081s
Transmission: Stock Non-WC T5
Axle/Gears: 9 bolt w/ discs
PM'd you
Old 06-21-2017, 09:29 AM
86IROC112's Avatar
Car: 1986 IROC Z
Would you happen to have the clip or clamp or whatever it is that attaches the MAF to the "Y" shaped air cleaner assembly?
Old 06-28-2017, 08:42 PM
TylerSteez's Avatar
Engine: 383 stroker
Fuel injectors and plenum are sold. still have everything else.
also have the cruise control system, stock vortec cam, and a bunch of TPI sensors
Old 06-28-2017, 09:21 PM
Car: 1987 Trans Am
Just received the injectors today, look great !!
Old 06-28-2017, 09:53 PM
TylerSteez's Avatar
Engine: 383 stroker
awesome, glad to hear
Old 06-29-2017, 12:09 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
How much for the base? 46268
Old 06-29-2017, 05:55 AM
vinny R's Avatar
Car: 1991 Z28
Got the Plenum Tyler....Thank you.
Old 06-29-2017, 08:43 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Still have the EGR and Temp switch? Price shipped to 35761?
Old 06-30-2017, 03:09 PM
TylerSteez's Avatar
Engine: 383 stroker
Hows $55 shipped?
Old 06-30-2017, 03:16 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Hows $55 shipped?
That works Tyler
PM your PayPal and I'll send in the AM.
Bob
