Vss sensors & gears lot
Old 12-16-2017, 01:04 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
New sc55 and two other vss unsure of gear size they can run $85 shipped in the states .
Red 37 tooth
Green 42 tooth
Old 12-16-2017, 01:11 PM
Engine: Lb9
Transmission: M20
Re: Vss sensors & gears lot
New yellow 41 tooth great for 3:42 gears $30
Old 12-20-2017, 08:52 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
PM sent.
Old 01-09-2018, 07:16 PM
Engine: Lb9
Transmission: M20
Bump
Old 01-12-2018, 02:08 AM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
Anything for a t5 with 3.73s?
Old 01-12-2018, 10:08 AM
prossi's Avatar
these are all auto trans right??
Old 01-12-2018, 11:27 AM
Engine: Lb9
Transmission: M20
Yes all for the 700r4
Old 01-18-2018, 09:33 PM
Engine: Lb9
Transmission: M20
Bump
Old 01-23-2018, 05:11 PM
Engine: Lb9
Transmission: M20
Yellow gear sold
Old 03-30-2018, 01:55 PM
Engine: Lb9
Transmission: M20
Bump
Old 04-13-2018, 09:28 PM
Engine: Lb9
Transmission: M20
Ttt
Old 04-14-2018, 12:20 AM
Drew's Avatar
Received 1,052 Likes on 748 Posts
Black should handle the numerically higher toothed gears, 40-45T? White should be the lower, 30-something. Just an educated case based on my best impressions. Pretty sure these are the later style, the earlier has the plug centered. Best bet is to research it for yourself to be sure.
Old 05-08-2018, 12:11 PM
Engine: Lb9
Transmission: M20
Bump
Old 06-29-2018, 03:25 PM
Engine: Lb9
Transmission: M20
Bump
Old 06-30-2018, 05:29 PM
Engine: Lb9
Transmission: M20
Looks like these are the newer 90-92 style Vss and should be 4kppm
Green and red gears available
Old 06-30-2018, 08:40 PM
Engine: Lb9
Transmission: M20
last of the yellow gears sold
Old 03-06-2020, 10:37 AM
Engine: Lb9
Transmission: M20
Bump for green and red gears and Vss sensors
ryxore
09-21-2010 08:13 PM
tonythetoad
09-21-2009 05:15 PM
Jessman
09-01-2007 01:07 PM
i roc k
10-05-2001 01:57 PM
Abe91Z28
12-30-2000 11:57 PM
Quick Reply: Vss sensors & gears lot
