[ID] WTS RHS polished single plane intake w/rails $375 shipped
have a racing head service (RHS) Polished single plane intake with fast fuel rails new.. (not used) comes with injector adapters (to use long or short injectors) $375 shipped. (NOTE! summits price for the unpolished unit is $549 without rails)
also have a kinsler TB Polished with GM TPS and IAC 1000 cfm $250
8.bosch 42lb injectors as new from FIC (fuel injct conetion) was 32lb (red top) remade into 42lb by them. flow matched new in box $275 shipped
The RHS® Single Plane 23° Aluminum Intake Manifold is engineered specifically to port match fit RHS® Small Block Chevy cylinder heads. Additionally, this manifold is the only one designed with bolt machining to fit all versions of Small Block Chevy cylinder heads, including classic originals, Vortec GM heads and late model perimeter corner vertical bolt style crate engine heads. It provides the power and strong torque curve throughout the mid-RPM range that is required for performance street, circle track and drag race applications up to 434c.i. The manifold also features auxiliary water ports, integral water crossover and dual sided distributor mounting points. Female pipe fittings at all four corners allow external water lines for reverse cooling applications.
▌Integral Sensors • Injectors Angled Directly At Valves • Uses LS-Style Sensors & Injectors
RHS® and sister company FAST™ teamed up to design the revolutionary port fuel injection version of these manifolds. Unlike the competition, the EFI manifold features port angle optimized injector mounting and machining features. FAST™ engineers laid the injectors down on an angle that points injectors directly at the valve stem. Additionally, the EFI manifold features integral air temp and MAP sensors improving function, fitment and packaging.
▌Information Summary:
- FAST™ red annodized fuel rails & hardware • Use common, standard (2.550" o-ring to o-ring) injectors or short (1.480" o-ring to o-ring) LS3/LS7 injectors
- Fits all "Gen 1" SBC heads ('55-'02) • From classic originals to Vortec to late-model perimeter corner vertical-bolt crate engines
- Port angle optimized injector mounting • Injector holes are machined so injectors are angled directly at valves
- Integral air temp & MAP sensors improve function, fitment & packaging • Uses LS1-Style MAP & air temp sensor
- Strong torque curve throughout mid-RPM range • Excellent for performance street, circle track & drag race engines up to 434c.i.
- 4150 flange works w/ aftermarket 4BBL throttle bodies or a late-model throttle body adaptor elbow of your choice
- Dual sided distributor mount • Auxiliary fittings at all four corners allow external water lines for reverse cooling
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
Re: WTS RHS polished single plane intake w/rails $375 shipped
….. Beautiful stuff ! … Awesome Gen 1 small block performance available here ! …..
UltRoadWarrior9
Alternative Port EFI Intakes
34
05-19-2020 04:08 PM
jonarotz
10-16-2015 09:51 PM
Hawk92z-TDZ
40
03-17-2015 08:41 PM
articwhiteZ
08-09-2013 07:32 PM
mhaskell
05-29-2007 02:55 PM
