WTS 700R4 w/trans brake.close ratio.and billet coverter.
made to move to a big block and the headers I had Made will not let me use the 700R4 I had made to work with My 427 SBC.
all top of the line parts Used.. the hard parts Sonnax and TCI came to over $3500. this has the 6 pinon Planet (sonnax) so you don't have the rpm drop from 1st to 2nd ..2nd to 3rd.. its now close ratio..like a Th350 or Th400 all billet input shafts drums. the case and output shafts have been cryo treated for strength. made to take 1000HP you could not build this today for under $3000.
billet pump gears. and most of the pump.all drums and hard parts are 100% new sonnax and TCI only the case and output shaft are used!
it also has TCI's new transbrake for the 700R4. with this setup you do not use a kick down.(billet plate blocking it off)
full manual valve body reverse pattern.
case is deburred and cryo treated done in a nice Hammer tone finnish
moroso fabricated aluminum pan. OR Polished Aluminum Pan
set up for AN lines..but ya can use the reg hard lines if ya want to.
this is a Non Lock up.
converter is a Precision Industries 9" billet unit 3500 stall
all the good stuff non lock up
speedo gears are set for 4.11.
this set is still Brand new..
there are a few places/makers selling a close unit to this for over $3500 with out converter.. and they don't look this good!
no kickdown
most of the parts used cost to much to build them like this...ya get over $4000 in parts for $3000 shipped
Note the red and green wires are for your TransBrake
$3000 shipped..
I have a new TH400 on the way.. and will ship this out in its packing..
no kickdown
$3000 shipped..
Re: WTS 700R4 w/trans brake.close ratio.and billet coverter.
What is the best price you can do ? I don't need it right now but if I can get a good deal I will buy it for later.
Thanks Kevin
Thanks Kevin
$2300 you pay shipping ($125) ball park could be less as if your in WA state its close to me Im in Idaho (Fastnal 3rd party ship)
remember its over $3000 in just hard parts..the converter it's self is over $700
could have it on a pallet on its way this week...
if your eng is internally Balanced ill kick in a SFI flex plate 168 tooth sbc/bbc
as you can see my TH400 was delivered 2 weeks ago..
and is all set to go..going to add a super bell.they shipped it so fast I could not add it to the order after thinking about it for 24hrs
going to refinish the case/Deburr it like I did the 700R4 case.just makes a better looking unit...and I like the hammer tone finish.
Car: 92 Z,92 RS,95 SS,00 WS6, 04 XUV
Engine: 383z,350RS, LT1, LS1 ,vortec 4.2
Transmission: 700R4, 700R4,4L60E,4L60E, Auto,
Did this sell?
pallets done. plastic wrap in hand...should ship out this week.
your trans & converter will be pack on the pallet with some free goodies
trans cooler and a SFI flex plate 168 tooth internally Bal sbc/bbc
TX-SleeperC5
06-09-2015 01:04 AM
C409
10-06-2013 04:36 AM
steve88iroc
09-29-2006 09:17 PM
