TURBO KIT
TURBO KIT
PRICE DROP.......... $800 OR BEST OFFER !!!!!
Asking $800 (located in the Bronx NY 10462)
BBS (Bermudez Brainstorming Designs) Turbo kit that was specifically made to fit 3rdgens.
The kit includes everything EXCEPT TURBOCHARGER.
The Turbo that this kit was designed to work with is a Turbonetics 62-1 but it looks like any turbo with a T4 flange will work.
It was also designed to fit the 85-87 V-belt equipped cars, but a serpentine setup can be used if you delete AC and the smog pump.
This is the same kit that is used on this car:
http://www.superchevy.com/…/0707gm-1...bird-f…/
The kit comes with the following:
Turbo header
Crossover Pipe
Driver's side header
Boost gauge
Alcohol Injection kit
Downpipe
Pipe to connect downpipe to catback
All oil lines
Tubing to run from turbo to the intake
Intake duct for the turbo and filter
2-BAR MAP sensor
Turbonetics WasteGate
The kit is set up to work on a TPI, but will work with just about any small block chevy.
If you want to run an intercooler, you have to buy an intercooler and run the piping yourself.
All you need is the turbo which costs around $800 (for a quality one!) and you have a bolt in turbo kit ready to go.
Turbo header
Crossover Pipe
Boost gauge
Downpipe
All oil lines
2-BAR MAP sensor
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: TURBO KIT
Free bump for you. If the buyer of this kit is interested I have a CXracing 4” intercooler with brackets. Not trying to hijack btw.
1 Post
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
Re: TURBO KIT
Any chance of u selling the meth kit separate?
confucius101
09-25-2019 09:49 AM
