[Sold] KC4 Modine Oil Cooler / Lines 87 IROC
$85 + shipping. Includes Cooler, Lines, Adapter and correct mounting studs,..... Everything needed to install. The rubber lines should be replaced, but are being included so you have an accurate guide to cut replacements; removed from an 87 IROC.
Send me a PM for details & include your ZIP CODE for a shipping quote if your interested.
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
Re: KC4 Modine Oil Cooler / Lines 87 IROC
Sounds silly, but how exactly does this work? Does it run through the stock radiator, or a external unit? Also does it use a certain style oil filter? Shipping to 97030 5413409876
It's a sandwich' type oil cooler,....... oil flows thru it and into the oil filter, then back thru it & back into the engine. The lines connect to the cooling system and engine coolant is used to help reduce oil temps. It does not require a certain kind of oil filter; I've got one installed on my LT1/T56 swap in an 84 Berlinetta and use an oversized oil filter from an 82 Chevy truck ( Fram TG5 or equivalent. )
Shipping from RI to OR is $45. Package is about 11 pounds & 25x16x7 in size.
mike_c
05-12-2012 02:14 AM
