Doing LT1 swap, does LT1's have MAF burn off??
I am knee deep into doing my wiring for my LT1 and I can't find a MAF burnoff relay in the Chiltons. Do LT1's have a Mass Air Flow Sensor burnoff relay?? Also anyone that has used a harness from an LT1 or maybe even a painless how maney relays did you have?? I have three (two fans and a fuel pump) there are some more sockets for relays but I didn't get the relays. Was the guy that sold me the harness greedy and took them or are there only three??
No burn off on MAF...
4 relays Fan#1, Fan#2, Fuel Pump, and A.I.R.
I deleted the A.I.R pump off mine and removed the setting from the pcm with tunercat. So no need for the relay.
Pic of my relays, taken before I complete the wiring.
Hey many thanx for the reply and info, it was a big help. That is a big help knowing what I am looking for!! I traced & found the AiR relay and the Fans. I still have two left trying to figure out which one is the fuel pump. I'm getting there wire by wire.
1992 Trans Am
Aug 8, 2015 08:16 PM
