turned the key and it fired right up!
Old Dec 25, 2003 | 05:05 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
just thought id let you guys know. its all worth it when you finally crank it. havent had this feeling in a long time!
im looking for performance numbers for my buildup. has anyone else duplicated my build?
4 bolt mains 350
cast crank and rods
hyper pistons 10.0-1 with 64cc heads
sportsman II heads (64cc)
air gap intake
speed demon 750 dp
gm hei distributor
lunati bracket master cam
230/230 duration - 455/455 lift
bw 5 speed
323 G80 posi trac rear
crane 1.5 roller rockers
hooker super comp headers (long tube - 2210, i think)
serpentine system with electric fan
Old Dec 25, 2003 | 09:30 PM
MdFormula350's Avatar
sounds like a nice setup. good luck with it.
Old Dec 25, 2003 | 09:33 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
How many cc's d the ports have on those sportsmans?
Old Dec 25, 2003 | 11:24 PM
Engine: 355
MD thanks man.
the sportsman II's have 200 cc's
Old Dec 26, 2003 | 04:36 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
setup below, should be around 9.7:1
cam is 110lsa/236/242 dur @050, 510/520 valve lift w/1.5's
i would suggest a cam with same lift, but little less dur...
Old Dec 26, 2003 | 06:35 PM
Engine: 355
ty
Old Dec 26, 2003 | 07:20 PM
fb305svs's Avatar
those hp numbers are at the crank btw...
also, im trying to figuer out a better cam combo...
Steve
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
Kaweh
Aug 9, 2015 02:54 PM
