couple of ??'s
couple of ??'s
Ok i'm planning on building up a 350 that my buddy has laying around and i'm wondering it is like a late 70's truck engine and i want to swap my TPI over to it for the power so i was wondering if the 70's blocks have the hole for the knock sensor and will & if so how will a 89 TPI setup work on a pre 87 engine. And for the chip problem if i just went and got a 350 Hypertech chip i've seen on thunderracing will that work instead of replacing my entire ECM?
another ? i was wondering since i've heard from this board that if you put bigger heads then you need on that it will lower compression ratio so if i put smaller ones on it will raise compression ratio but would that also kill power????
Transmission: 4L80E/4L80E
Re: couple of ??'s
RedLeader289
May 28, 2019 01:47 PM
Linson
Oct 1, 2015 09:50 PM
