solid motor mounts
Old Apr 21, 2004 | 08:20 PM
bubba377's Avatar
solid motor mounts
Is anybody using solid motor mounts? If so how bad does the car vibrate? are they worth it or should I just put the stock ones back in . I am buying the paracing k member and might use the solid motor mounts when I put the motor back in
Old Apr 22, 2004 | 09:59 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
If It were my car I would not run solid mounts especially for street driving. If the car is being build just for the track that's another story.
Old Apr 22, 2004 | 12:45 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Re: solid motor mounts
I have a couple friends with them, they arent nearly as bad as people make them out to be. Granted they arent daily driver material, but sounds like you have a pretty stout motor. I say go for it.
Old Apr 22, 2004 | 01:19 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you're feeling for it, ofcourse you can tell.
but if the exhaust is already dumping under the car, the vibrations are going to be about the same...
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
