Value of this long block??
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
http://www.golenengineservice.com/di...fm?EngineID=34
golen engine service 383 TPI long block. for 5200 bucks?
ECM chip for $540.
uses eagle rotating assembly which is about 1000 right there and AFR heads are 1400 or so. i think i can build one for less tho. what do you think? is it worth it?
ECM chip for $540.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I have roughly $3500 in mine peicing it together. Most shops only get $1-400 to assemble an engine
Yes that cam is about the same as the GM Hot cam kit, can't remeber what it costs, but since the heads come with springs and retainers you could buy the cam seperate. Figure $3200-$3500 if you have a block and it is ready to go.
Car: 89 Iroc-z
Transmission: TH400
LOL, sure i think i may just do that and part it out. its got some mileage on it but runs great and i havent really beat on it either
Car: 91 Z28
Transmission: 4l60e
how much you parting it out for? cuz im deff interested
edit: plus your only about 70 miles from where i live. i wouldnt mind the road trip
Car: 89 Iroc-z
Transmission: TH400
i'll find out when i am able to do this motor build up. might not be till late fall 05 LOL
New2Chevy
Sep 28, 2015 12:35 AM
