400 SBC
Old Jun 29, 2006 | 11:44 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
400 SBC
this is just a thought, but ive been thinking about building a 406 for my L98 formula 350. i was wondering if the motor mounts are the same and if the accesories would be in the same place, seems to me like they would be...but i could be wrong, thanks in advance.
Old Jun 30, 2006 | 10:45 AM
jms's Avatar
jms
Yes, you are correct. However, you will need to use the 168-tooth 400 flexplate and most likely have to get a different starter than the one you now have on the car.
jms
Old Jun 30, 2006 | 10:51 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
everything will work, except:
1. you need to drill steam holes in the heads. not hard. the heads can still be used on non-400 SBCs too.
2. you need a external balance harmonic dampener.
3. you need a external balance flexplate/flywheel.
4. you may need a new starter to match the flywheel/flexplate.
Old Jul 3, 2006 | 05:16 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
I have a 406 with Edelbrock heads in my 69 Camaro. I've swapped in the serpentine belt system from a 90 Iroc and it fits just right. Alot easier than all those pulleys and vbelts. I will use the modified belt setup that bypasses the smog pump.
VR,
DZcode
Old Jul 5, 2006 | 12:46 PM
rhamm1320's Avatar
jms
I agree, check your starter mounting. I had to drill a new hole in my block in a gravel driveway on my back because I didn't check the starter before installing the engine
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
