COMPRESSION QUESTION?
Old Dec 13, 2006 | 11:14 AM
FJA's Avatar
FJA
Car: 1986 & 87 Camaro
Transmission: 700R4 & PG
Axle/Gears: 28spline 4.10 & KTRE 12 bolt
About what compression will I have with a stock L98 short block and stock Corvette aluminum heads. Also thinking about running a ZZ4 camshaft with a Performer RPM. What kind of HP #s should this combo have. (350hp?) Can I still run pump gas?
Thanks Frank
Old Dec 13, 2006 | 01:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
CR will be about 10:1. HP should be in the 350 range with the ZZ4 cam and good exhaust on pump gas.
What is a ZZ4? A 4-bolt main 350 with Corvette aluminum heads, roller cam, Performer-like intake manifold. With 650 CFM carb and headers, it makes 355 HP. The RPM manifold should only help.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
