will this fit
Old Mar 29, 2008 | 05:39 PM
jefflawless's Avatar
will this fit
i bought a 83 chevy 3/4 ton truck with a 350 small block chevy but will the motor fit and wire up the same as the camaro v8's or no
Old Mar 29, 2008 | 07:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Only if you use all of the induction/exhaust/accessories from the Camaro.
If, of course, your Camaro has a V8. If it has a V8, then we need to know more about what you've got.
In fact, more details about your Camaro would be the only way to give you detailed advice.
Old Mar 29, 2008 | 11:13 PM
Re: will this fit
well right now it only has a 2.8 v6 in it with a 5 speed tranny
Old Mar 29, 2008 | 11:18 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Re: will this fit
I dont think so
Old Mar 29, 2008 | 11:57 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Re: will this fit
It will fit but first you have to change your motor mounts, get a rad from a V8 camaro, a set of headers or manifold from a V8 camaro, u will need a new intake depending on if yours is fuel injected or carb, your trans probably won't bolt up to the 350 so you'll have to get a V8 bellhousing.
I did the same swap on a 82 camaro it was a 2.8L originally, I put a 350/turbo 350 trans out of a 74 chevy half ton pick-up. It was alot of work but worth it in the end. 2.8s suck I blew mine up on the first day.
Old Mar 30, 2008 | 01:03 AM
ljnowell's Avatar
Re: will this fit
The trans will not bolt up to a v8. Getting a v8 bellhousing is a bad idea also, as they are not of the same strength. you will need a v8 trans, and not the one from the truck its a different flavor. My ol 2.8 was a good engine, I ran it till it hit 155k then pulled it in favor of a hot 350.
Old Mar 30, 2008 | 02:04 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: will this fit
The trans will bolt up, using a V8 bellhousing, and the right clutch disc, it will hold up for most normal driving, especially on street tires, i put plenty of miles hard driven on one with a 305 tpi that turned a 15.8 easy with no mods. The key is traction and how you drive it, and knowing its not the strongest thing ever.
Old Mar 30, 2008 | 02:30 PM
five7kid's Avatar
Read the sticky in the top section of this forum about V6 to V8 swap, then ask your questions.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
