fuel lines
Car: 1989 Camaro
Engine: building a 350
Transmission: TH350
Axle/Gears: soon to be 4.10 non posi
fuel lines
so I got looking at the fuel lines I am going to run (off a carbd setup), and the hard lines have been cut toward the motor end of them. since I will be running my EFI pump with a 3 port regulator Im concerned about the pressure leaking past a cut steel line with only a hose clamp holding the rubber line. I was wondering if I can just flare the end of the hard line for some extra security and be okay with a hose clamped rubber line? I really dont wanna buy another set of lines.any ideas??????
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: fuel lines
if you use the proper hose and clamps it wont be an issue to leave it alone. If you flare the tubing, it will create an edge that will eventually cut through the hose and blow.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
