'89 TPI Unit
'89 TPI Unit
Monday I am going to go remove an 89 tpi unit from a wrecked IROC. I was wondering what tools I will need to bring along with me so I don't have any surprises when I am removing it. Also, what other tpi parts will I need to remove from the car to make the swap from tbi to tpi besides the intank fuel pump, ecm, wiring harness, intake manifold, plenum, runners, injectors and throttle cable. Will I need to get the wiring harness that is in the dash as well so that my gauges will work? Any suggestions would greatly be appreciated. Thanks in advance.
Don't forget the sensors and stuff!
'86 IROC Z28 TPI 305. Modified air box, K&N filters, Air Foil, SLP headers and exhaust sytem, Comp Cams 1.52 Magnum roller tip rockers and springs, lightweight valves, Accel Super Coil and wires, Adjustable FPR, and tons of elbow grease!
Grab absolutely everything they'll let you take. The little stuff will nickle and dime you to death later if you don't. Remember to take some Torx wrenches, too, in case you decide you can't take it all off in one piece.
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
if your car is a 1990 or later you may not need the fuel lines.after 90 GM went with a 3/8's fuel line on all of the fuel injected f-body's.tune post and throddle body
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
evilstuie
Apr 14, 2016 08:52 PM
Sanjay
Aug 12, 2015 03:41 PM
