zz4 swap!
Old Aug 26, 2001 | 09:32 PM
pronger44's Avatar
zz4 swap!
I read an article in super chevy about putting a ZZ4 in a camaro and sounded pretty easy. is it as easy as it sounds or am i being mis-lead? has anyone else ever done this? what are some problems I may encounter?what are some things i can do to beef up the tranny? all you're input is appreciated.
Old Aug 27, 2001 | 08:17 AM
91-ZZ4-Z28's Avatar
The swap is easy but has a few snags. Depending on the year of you car (if you has a serpentine belt or multi belt system and the bolt angle of you center intake manifold bolts) on my 91 the pass. side head had to be drilled for the AC bracket to fit and I would have had to re-drill my manifold boltholes but I went with a super ram base that is drilled for both. Other than making sure you change the ZZ4 water pump to a reverse rotation like is on you car now and depending on the year of you car it may or may not have a roller cam (has small dis. shaft size 90,91,92 I think) if it does than your old distributor will be fine work fine if not (older cars larger dis. shat size you will have to swap the gear off of the one that comes with the ZZ4. It is an easy swap well worth the effort but take my advise don't use your stock base and runners get a high flow base from Edelbrock or Accel and runners from AS&M or SLP and port your upper (SLP must be ported to make as much power as AS&M) the stock tpi just does not flow enough to keep the ZZ4 happy. I hope this helps a little.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
Old Aug 27, 2001 | 08:22 AM
91-ZZ4-Z28's Avatar
Your tranny may be ok for street driving but if you plan to take it to the track and hook up you will kill it, have a pro shop build it for you that kows how to build it for the level of power you will have. Don't just get a shift kit and think it will hold up.
Old Aug 27, 2001 | 09:15 AM
MouseCamaro305's Avatar
the ZZ4 comes with it's own distributor, doesn't it?
Old Aug 27, 2001 | 10:02 AM
91-ZZ4-Z28's Avatar
Yes, but it is not the appropriate HEI distributor to use with a computer controlled ignition on the TPI system it will not work.
Old Aug 27, 2001 | 10:23 AM
RayZeR14u's Avatar
Hey pronger44 this is off the subject, who do you run with in Indianola? I grew up in Milo and finished High School in Indianola. In fact I use to live with Corey Taylor(singer for slipknot) and his Grandma in Des Moines after high school before I moved to S.C.
[This message has been edited by RayZeR14u (edited August 27, 2001).]
Old Aug 27, 2001 | 02:52 PM
black83z's Avatar
In an 83 Z with crossfire, would it be possible to swap in a ZZ4, put on a carb and get rid of the computer? Or is the computer needed for the transmission? Are there any clearance problems if a Holley 750 is used?
Old Aug 27, 2001 | 03:06 PM
Matt's Avatar
black83z-only if you have an auto is the computer needed for torque converter lock up but a cable is available i think, no sure but someone else may know more.
Old Aug 27, 2001 | 09:54 PM
pronger44's Avatar
who are some people you know in indianola, des moines,and milo?
Old Sep 6, 2001 | 11:55 AM
RayZeR14u's Avatar
<font face="Verdana, Arial" size="2">Originally posted by pronger44:
who are some people you know in indianola, des moines,and milo?</font>
Daron Quick, Damon Hunter, Phil Hunter, T.J. Rogers(Tuck),Josh Jennings, Chad and Brian Six, Jason Merzina(not sure how to spell his last name) Aaron Van Syoc, Chris Manley(Critter), Dustin Shafer. I could go on and on.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
bamaboy0323
Sep 3, 2015 06:07 AM
italiano67
Aug 31, 2015 06:04 PM
