Ingredients to a 406...?
Old Oct 20, 2001 | 08:09 AM
Matt86Z's Avatar
Is a 406 just a 400 SBC bored 30 over?
I've got a set of "192" 1969 302 heads with big valves, is this a good combination of engine/heads?
Matt86Z
~Check out my Thirdgen~
...This Ain't No Speedway!...
Old Oct 20, 2001 | 11:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, that's all a 406 is. A 400 that was worn out and has been repaired. It is not some kind of separate creation.
I don't know what you mean by "192" heads. What's the casting number?
ICON Motorsports
Old Oct 20, 2001 | 11:58 AM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
TO make a performace engine out of a 406, you need a good set of heads. The biggest intake runner on GM factory production SBC heads is 171cc. This is the Vortec design. Personally, I would go bigger. The 400 is choked off by small heads and they need to breathe. I would go at least 200 or slightly bigger. 400's are naturaly torque motors, so if the runner was just a little on the big side, it wouldn't hurt that much.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Old Oct 20, 2001 | 04:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Agreed. The 192 heads were feeding a 302. You're now trying to squeeze the same amount of air into a 406. It will work but you're giving up a lot of HP with the restricted heads.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Oct 21, 2001 | 07:28 PM
Matt86Z's Avatar
Say I'm shooting for tons of low end, wouldn't the cam have more to do with that than the heads? They've got 202/160 valves in them, I know they flow well because they were feeding the mid 13-second 355 that I had in the car before it blew up.
tom1985
Sep 4, 2014 11:58 AM
88fastgta
May 4, 2011 07:44 AM
MrDude_1
Oct 23, 2003 03:44 PM
Sciguyjim
Jul 8, 2002 05:17 PM
GTA88
Jul 18, 2001 09:00 PM
