350 swap, need help
350 swap, need help
what all am i going to need to change out when i drop a 350 tpi in my RS 305. Can i keep the auto tranny? I dont know jack aobut what i need to get other than the engine... NEED HELP
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Do a seach for 350TPI swap on the archives. It would be better if you could get the complete motor with wiring harness and ECM. As far as your 305 auto tranny mating up with a 350, ot will bolt right up. What year is you Camaro RS?
Transmission: 4L80E/4L80E
As long as you get an '87-later 350, absolutely everything will bolt on to it from the 305. Externally, they are identical.
You can get the 350 running with the 305 TPI with little more than an adjustable fuel pressure regulator (set with a fuel pressure gage you're going to add to your tool box). After that, 22 pound injectors, custom chip, etc., will help optimize the setup.
From what I've heard, Jasper is an okay place to get a replacement engine. But, a crate motor from SD or Jim Pace will get you a GM warranty on a brand new engine for not a whole lot more (if any) money.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2200 stall TC. Ported World 305 heads, Crane PowerMax cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster. 2.93 limited slip, Spohn SFCs. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited November 14, 2001).]
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Check out goautocenter.com for brand new GM crate motors.They have lots of optional cams,heads,etc.
I bought their TPI 300HP 350,but ordered it with TBI roller cam,for my RS.
Paid $1855 and it's all brand new parts.
The serpentine belt setup should bolt right onto the 350, but I don't know if it's different for TPI vs. TBI,so there may be an interference issue.
Like 86z/92rs said, best to get whole motor/harness,ecm as a package if you can.
I know the TBI and TPI use a completely different harness and ECM.
Rich
Rich
