quick ? for common knowledge
Old Dec 14, 2001 | 05:43 PM
82sportcoupe's Avatar
ok, just for common knowledge. a 305 w/ factory 350 heads would significantly decrease the compression ratio of the engine. I agree, but wouldnt that help the air starved engine breath alot better, hencethereforth, wouldnt the engine run better? im a little confused on the subject. technical answers and numbers would be greatly appreciated. The question popped in my head while reading another post.
The only thing better than taming ponies is burning rice!
1982 Camaro Sport Coupe
350 cid
Performer Power Package
4.10 posi
Old Dec 18, 2001 | 01:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Try #2 (first reply lost by the system):
Don't assume "350 heads" will flow better than say LG4 heads. I had a '71 GMC 3/4 ton w/4-bolt main 350 that had 1.72" intake valves. Trust me, those heads would NOT be an improvement on a 305.
Some have put Vortec heads on a 305 without shaving down to 58cc. With cam and exhaust improvements, you very well may have more power than before. But, with some porting work on the 305 heads and the cam and exhaust improvements, you'd also have more power.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Fanatic1074
Oct 2, 2015 03:47 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
