Engine upgrade ideas.
I just bought a 92 trans am convertible, automatic 305 tpi. Engine is bad and I plan to get a long block. So here are my questions for those who may have been in my same shoes. First let me relay that I want to keep the fuel mileage close to stock or better.
Option 1. Long block 305 and keep stock or mild upgrades.
Option 2. Long block 350, and what ever is needed for that swap.
Car: 83 Pontiac Trans AM
Engine: 305 CFI
Re: Engine upgrade ideas.
Would go 350. Depends on what mods, you're looking for. Going faster always costs money. 87-95 engines can still be found, or a crate engine for under $1500. (two bolt mains). About 2G's for 350/350hp or 383. Everything should bolt on for a direct swap. if you're going 305 you'll spend more than that to get the same hp.
If I was to put the 350 in It would stay stock. I would buy the knock sensor, injectors, eprom, headers and that's it. I will be driving this 80 miles per day so I'm not looking for high performance.
The 350 will probably give you better mileage, because you will not have to put your foot in it as much as the lame 305.
Car: 89 GTA Trans Am
Engine: 5.7L L98
Axle/Gears: Factory 10 bolt with Stock Gears
I'm a 350 fan myself. My MPG is pretty good and is pretty mild mannered.
Engine: 5.7L L98
I'm getting around 20 highway miles per gallon. Don't ever drive around in the city so I'm not sure what my MPGs are for that. I just did a much needed tuneup so that should help bump those numbers up a little.
If it's not a simple bolt in swap where all the harnesses and everything stays the same I am not interested. I've done a 22R swap on a Toyota that didn't turn out well and a 2.5 swap on a Mazda 626
