starter hi torque
Old Apr 24, 2018 | 04:50 PM
newfieirocz's Avatar
Car: 86 IROCZ, 2012 Impala LT
Engine: 383 stroker 4 barrel
Transmission: 700r stage 2 stift with 2800 stall
Axle/Gears: 373 posi yukon sure grip
starter hi torque
i have a 86 IROC with a 305 swapped to a 383 stroker with 168 tooth flex plate, my starter is a high torque and shot problem is which GM starter do I get, My block is a 86 1 piece rear seal any recommend which starter to get trying to get it running tonight show and shine tomorrow nite
Old Apr 25, 2018 | 01:49 PM
83 Gman's Avatar
Re: starter hi torque
Did the old engine use the same flywheel ? Diameter and amount of teeth ?
Here's one from Summit, you can cross reference to find one sold at your local parts house.
https://www.summitracing.com/parts/p...make/chevrolet
This one is large case, high torque, with a staggered bolt pattern. Don't know how many teeth on pinion.
Call to Summit may help answer that.
dahuntin
26
May 11, 2022 10:01 AM
HawkFanatic
Jun 26, 2018 03:01 PM
Silverado1320
Mar 7, 2018 12:09 PM
Silverado1320
Mar 6, 2018 09:31 PM
ndndndnd
Jan 9, 2017 07:45 AM
