Go Back  Third Generation F-Body Message Boards > Tech Boards > Engine Swap
Reload this Page >
1989 camaro rs 305 TBI to 350 TBI
Old 03-16-2019, 10:45 PM
Car: 1989 Chevrolet Camaro RS
Engine: 5.0L 305 V8
Hello everyone. I just have some general questions. My 305 just had its rings fried and the price they quoted me for the rebuild make me want to reconsider and swap for a 350. Here's the thing. I dont want to do an ls or lsx. I'm all about simplicity and less headache. From the research I have done. A 305 and a 350 small block are virtually the same exterior wise and dimensions except the displacement which makes me confident that all the brackets and smog equipment and manifolds and my 700r4 tranny would probably fit including my tbi unit. My general question is that since it's a computer controlled tbi, would the prom have to be reprogrammed to compensate for fuel or o2 sensor threshold needs to be adjusted. Stuff like that to avoid a constant check engine light and performance issues? I'm not looking to build a racecar but I've heard that 350s are more reliable than the 305s.
metalhead8711 is offline
Old 03-17-2019, 11:39 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1989 camaro rs 305 TBI to 350 TBI
Same outside dimensions. You need to look at if the 350 is a one piece or two piece rear main seal. This will determine what flywheel is used and if you need to modify the 4 inner holes of the intake manifold to work.
Yes you should get a prom and larger 350 injectors. Rock auto has a good deal on the injectors just lookup a 87/92 k or c Chevy truck. Or use standard products tj7t . Othing makes a 350 more reliable. Itís just a smaller engine cid wise.
Tuned Performance is offline
Pilotrick50
04-11-2016 08:55 AM
falconman
05-06-2013 07:40 PM
slowboy43
08-17-2009 11:39 PM
LAN_Lord
South Central
03-06-2009 09:18 AM
Lewism111
07-27-2006 08:04 PM
Quick Reply: 1989 camaro rs 305 TBI to 350 TBI
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
