91 rs fuel pump wire??
Car: 91 RS B4C
Engine: 355
Transmission: TH 350
I have a 91 rs ex TPI car, I need to find the fuel pump wire under or near the dash to put a switch on it for the carb, I am running a bypass reg. Thanks for any help
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I picked it up from the harness right behind the rear seat before it goes through grommet in the sheetmetal. I wired the gray wire through a relay to come on with the ignition,and added a switch inline before the relay to turn off the pump for an emergency or when I neede the ignition on for a period of time without the pump running.
I picked it up from the harness right behind the rear seat before it goes through grommet in the sheetmetal. I wired the gray wire through a relay to come on with the ignition,and added a switch inline before the relay to turn off the pump for an emergency or when I needed the ignition on for a period of time without the pump running.
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
When I went to a carb setup from TPI, I found the fuel pump relay on the drivers side firewall. There is a grey wire coming off the relay into the car. I would venture to say this is the same wire that can be found under the carpet, but much more accesable. I wired up new relays to siplify things anyway. Put 12V to the wire, you should be able to hear the pump kick on.
Car: 91 RS B4C
Engine: 355
When I bought the car all ecm stuff and relays on firewall are gone thats why I want to find it somewhere under drivers side dash? Thanks for the & any more info.
Originally posted by Coxy
BTW, Rspeed I think your car is slammin.
Yeah,they are the long tubes.The plugs are AC Delco,but I can't remember which ones.#RT45 maybe.I'll try to remember to check for ya in the morning.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
