Advice in UK
Advice in UK
hi all,
im currently looking at getting a gen3 over here in the UK. I’m based near York and wondering if anyone has any first hand experience of garages who may be able to do whatever conversion work may be nesessary in getting a US car road legal for UK.
many thanks
Adi
many thanks
Adi
Location: *member since 1999, I think - just can't remember my old name, and the big site crash...*
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Car: 1988 Trans Am GTA
Axle/Gears: 3.70
Re: Advice in UK
I am stationed in the UK currently. I brought my car over with me. The conversion only involves getting the light rewired to meet specs. Pretty much any of the garages down near the American bases can do the work. Depending on year and model that you get will change the amount of work that needs to be done. For a specific garage there is Coopers garage in Mildenhall that a lot of people use for light conversions. I did all the conversion for the rear myself. It really wasnt hard. The other issue to worry about is the parking brake. The parking brake setup sucks if it is the early style calipers. I am wrapping up from upgrading my brakes because of this issue. Even with all new factory stuff the parking brake isn't that good. Would love to see more third gens here.
Re: Advice in UK
Thanks, Im relatively competent and would happily have ago at this if there’s a guide available?Also, what’s the rules regarding side indicators/repeaters?Thanks for the help
Re: Advice in UK
Might try Robin Gray:
http://www.autopontiac.co.uk/about.shtml
Thank you, I’ve dropped them a line.
Axle/Gears: 3.70
Re: Advice in UK
Basically for the rear if you get one that doesn't have the amber lights like a base model firebird some years you ha e to make the rear turn signals work with amber bulbs. I used the reverse light but changed the sockets out to the dual filament bulb like the other bulbs. I was able have them then be the turn signal and reverse lights. Also the reverse fog light needed to be hooked up. I just wires it into the existing front for light switch. The fronts technically need to have the marker lights and the turn signals separated. The marker lights need to be white and turn signal amber. The side light should be the same concept. To be honest I didn't end up doing the front. I was able to pass the mot just fine. It is mostly looking at the diagrams to see what wires need to be rerouted. I would be able to be more specific if you knew what year and model you were getting. I can help if you move forward with getting one. I will be driving mine again soon hopefully. Just need to fix rear end leak.
Re: Advice in UK
Great. Thanks for that. I’ve currently got my eye on 2 different ones, just a case of the US seller happy with me being in th UK...
Re: Advice in UK
A bit more advice required. Seriously looking at a 1985 trans am based in Washington. I’ve just been sent a video of the instrument cluster send the speedo only goes to 80mph full scale??? Didn’t look right to me-any ideas?
Re: Advice in UK
Hi, thanks for that. Not personally keen on front end on that one. I’ve gone ahead with the 85 (after much research)- just awaiting shipping to be arranged. Can’t wait!
Aaron's 87
Aftermarket Product Review
11-04-2000 09:32 AM
91Z28
10-26-2000 11:08 AM
