extremely STUPID question
Car: 1984 Z28
i dont even deserve to live for asking this but.. If i bought a Hooker Cat back. what is the diff between a cat back and... a muffler or something. or is that the same thing.
Car: 99 Formula
Axle/Gears: 342
Originally posted by 84Z28_5.7ltr_V8
makes sense i guess.. So would u still have a muffler?
Car: 99 Formula
Axle/Gears: 342
you think im an idiot dont you.
so you pretty much get a cat back AND a muffler all in one!
that last statement is right, i guess.
but a cat-back is exactly that everything from the cat, back.
I dont run a cat because I dont wanna get stranded on the interstate somewhere because my catalytic converter decided to stop up. Plus they kill performance one they start to go.
Put a pipe in its place and guess what...flows better, wont stop up, and sounds better....
I do wanna make a fake cat like brodyscamaro did so i can pass state inspection easier.
A cat back exhaust system includes a muffler. It's everything behind the cat. Don't be worried about your catalytic converter getting plugged, it doesn't happen as often as people think. If you have to pass smog every once in a while you'll end up replacing it because it's been poisoned enough that it doesn't work well before it gets clogged.
Car: 99 Formula
Axle/Gears: 342
Originally posted by SlowMaro
heh i shoulda put a pipe in place of my cat but im lazy and cheap lol...plus it resonates a lil better with the gutted cat on there
lol im lazy and cheap....ill put a straight pipe there in aminute i suppose. i shoulda just done that when i put my new headers on, ah well no big deal, itll take 5 minutes to do
besides im bored. gives me somthing to do heheh
besides im bored. gives me somthing to do heheh Thread Starter
Car: 1984 Z28
its nice living in saskatchewan where you dont have to pass smog things or whatever the hell you guys call them . i have never driven a car with a cat ever.
Car: 1984 Z28
i have another stupid question. The bigger your exhaust pipes, the louder it is and the more HP you get right.. or is it the smaller the more HP caause of more compression or soemthing. for example. If i got hooker headers with a 3 inch out into a 3 inch muffler inlet, and then out the 3 inch outlet into 3 inch tips would that be good?
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
correct me if i'm wrong....but the smaller the pipe (obviously not TOO small, though...) the more it helps low-end torque because it increases velocity of the gases, but during high-RPM periods the cylinder can't fill as much due to the small size of the pipe, therefore somewhat hindering high-RPM horsepower....
and the larger the size of the pipe, the better the high-RPM horsepower because the engine can gulp in air and fuel (and push more out), but the poorer the low-end torque because the air/fuel charge isn't moving quickly enough to pack into the cylinders, due to the low velocity.
i'm pretty sure this is how it works...
Car: 99 Formula
Axle/Gears: 342
so instead of going to 3 inches go to 2 and a half? or 2? 3 would look mean and sound mean.. VROOOOOOOOOM
Here's the order, from the heads
1) Exhaust goes through the headers
2) To the Y pipe (it is what it sounds like)
3) To the catalytic converter (the cat)
4) To the muffler
5) To the tailpipes
Some people replace from the cat-back so that they can avoid the expense of the replacing the headers (not cheap and a lot of work). Buying a high-flow cat and a new muffler will help free things up a bit and give you a better sound, but ideally you'd want new headers, a high-flow cat, and a better flowing muffler for the best performance.
4) To the muffler
5) To the tailpipes
Car: 1984 Z28
like i said earlier, i was looking at some hooker headers with a 3 inch out, and a hooker aero chamber muffler (i think thats what it was called) with a 3 inch out.
