What starter do I need with Hooker 2210's
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I took my old shortie headers off today and am trying to get he Hooker 2210's installed. It does not look like my full size starter is going to fit. Could someone give me a part number of a down sized starter preferably with the offset bolt pattern that will fit in there.
Car: 1986 Iroc
My 406 has the staggered bolt starter so I wasn't sure if and LT1 starter would work or not. Anyway I found the starter from a 1994 K-1500 Chevy halfton with a 350 has the small starter with the staggered bolt pattern and it worked out great.
Car: 1986 Iroc
Thats great. Now we know a couple of starters that will work in tight spots with the staggered bolt pattern.
Car: 1986 Iroc
I can imagine how tight it is. I was a bit concerned about how hot the starter would get being that close to the headers. Have you had any trouble starting after it has been driven for awhile?
Car: 82 Pace car
Engine: Small block
Transmission: TH350
No but if heat soak becomes a prob i am going to wrap the starter with a heat blanket to protect it. I am more worried about my brake lines---they are REALLY close in alot of places---but they will all be wrapped before summer.
Car: 1986 Iroc
I thought the brake lines were to close as well so I moved them a bit further away from the headers. I now have about 2 inches of clearance on the brake lines.
Car: 1986 Iroc
Here is a pic of my Hooker SC lt's installed with the downsized truck starter I used. It also shows how I ran the starter wiring in from the back of the engine.
no green
Jan 9, 2016 09:22 PM
Gunner242
Dec 25, 2015 04:49 PM
