SLP Header Q (Please Read)
Old Oct 18, 2001 | 04:11 PM
88 Camaro SC's Avatar
Car: 99 Trans Am
I'm hoping to get a pair of SLPs, but I already have a problem. The one's I might get from someone are for dual converter cars. My question is, how would I get a good after cat system put in if I don't wanna put cats on? Would I be able to get a shop to weld on another pipe to join the two? Would that be bad? Another thing I was thinkin was to go and get two small mufflers, and attach them after the Ypipe, then add a turn down pipe or something. I'd just like some advice, for I need to decide if I would have any use for dual cat headers, since I'm getting an awesome deal on them. Thanks guys.
1988 Camaro Sport Coupe
  • Custom Interior
  • K&N Air Filter
  • Custom Ram Air
  • 180* Stat
  • Shift Improver Kit
Homepage: www.rsdragster.cz28.com
Old Oct 18, 2001 | 04:13 PM
breathment's Avatar
most reputable muffler shops wont let u get away with just ONE cat when you NEED two, but then again they might, why not just run true dual exhaust??
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 18, 2001 | 04:47 PM
Car: 99 Trans Am
True duals was something I really wanted to do a while back, but I decided not to sacrifice any ground clearance. As far as a shop not doin any work, would I be able to do anything? Something like the previously mentioned stuff: puttin on two mufflers right off the Ypipe, then gettin some turndown pipes. Wouldn't that work? Thanks again.
Nate
Old Oct 18, 2001 | 07:24 PM
82resto's Avatar
Most shops around here won't work on a car that doesn't have the proper number of cats equipped.
It's a violation of federal law... i.e. it's a felony finable up to 100,000 or so.
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
SLP 1 3/4 headers
No Smog/AIR system
Old Oct 19, 2001 | 01:52 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The headers are the same whether you have a dual-cat or single-cat exhaust. Its just the y-pipe that is different. You can have them make up a new y-pipe or adapt the dual one into a single setup.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 19, 2001 | 10:15 AM
mcconahay37's Avatar
You could also order the single cat y-pipe, install your headers, and drive over to the exhaust shop to have the rest of the exhaust put on. You might be able to get away with that.
Old Oct 19, 2001 | 11:42 AM
Car: 99 Trans Am
I probably won't bother gettin a new Ypipe, or converting the dual into a single. I think the easiest thing would be would to just get two mufflers and put them at the end of the Ypipe. But, since I have hardly any knowledge pertaining to exhaust, I need to know if that will do the trick. I would just like some info on whether or not it will work, and If I'd be holding back any power. Thanks again,
Nate
Old Oct 21, 2001 | 12:37 AM
Kevin91Z's Avatar
There's not enough room under there to put a muffler right after the y-pipe. It'll drag on the ground.
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
formula_novice
Sep 5, 2015 03:58 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
