How do I get the honeycomb thingie out of my cats?
Old Mar 30, 2004 | 06:16 PM
Mike89GTA's Avatar
I tried hammering it but it's harder than I thought it would be. What did you guys do?
I didn't really want to gut them, but they're making an annoying rattling noise anyways..
BTW is it normal that only 1/2 of the cat is filled with the honeycomb stuff?
Old Mar 30, 2004 | 06:18 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
Try a a cutting torch or whatever its called
Old Mar 31, 2004 | 02:22 PM
DaGoat's Avatar
A big stick.
Old Mar 31, 2004 | 02:32 PM
Mike89GTA's Avatar
I tried a crowbar and it barely dented it. hmm
Old Mar 31, 2004 | 02:40 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
cut the cats shell in half..... along the seam.
put straight pipe in place of cat.
weld cat shell back together over the pipe.
this way, your exhaust wont sound like ****. it also wont lose volicity from going into the larger cat, and then creating backpressure as it tries to go back into the smalled cat exit.
Old Mar 31, 2004 | 05:23 PM
rich3114's Avatar
Car: Trans Am
Engine: 455
Transmission: TH350
I used a steel pipe and a BFH, worked pretty well.
Old Mar 31, 2004 | 06:32 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
use a big stick AND a hammer Just keep bashing it and it'll eventually start to break apart.
Old Apr 2, 2004 | 09:01 AM
mettalicirocz's Avatar
Car: 1986 camaro, 1993 nissan altima(winter beater, 1992 mustang (summer daily driver)
Engine: 350tpi
Transmission: 700r4 with shift kit
I used a sharp pointed rod and a bfh and it worked very well more than once.
Old Apr 2, 2004 | 12:24 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I used a long screwdriver, and a BFH... worked well...
Old Apr 2, 2004 | 12:35 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
crow bar and hammer......i would recommend the straight pipe through the cat. sounds a little better and smells better.
Old Apr 4, 2004 | 03:25 PM
nolanr0413's Avatar
Car: Trans am
those ways all suck ***, i just did it like an hour ago, use a big drill, my dad has a big drill bit like 2 ft long and like 7 inches of drill and that worked perfect . The car is way louder now. Its sweet.
Old Apr 4, 2004 | 03:42 PM
Mike89GTA's Avatar
I really don't want to gut them, I just want to get rid of the rattle..
Old Apr 5, 2004 | 09:08 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
then replace them... not being rude, just stating the obvious....
seriously though, if the light rattle bothered you, the noise it'll make gutted will drive you batty...
if you can get a cutoff wheel, the method i mentioned works great. it looks like a cat, but it flows and sounds like a straight exhaust.... no rattles either.
Old Apr 5, 2004 | 09:31 AM
Mike89GTA's Avatar
I'm just selling the car and I want to fix it before I try selling it. I can live with the rattle, but the next owner might not want to..
Old Apr 6, 2004 | 06:00 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
then when u sell it tell the person u will fix it but the price will go up
Old Apr 6, 2004 | 06:22 PM
Mike89GTA's Avatar
Alright, I just gutted them, wow that was easy. I didn't know they were only a couple inches thick, I thought the whole cat was filled with the honeycomb stuff. The car seems to breath easier now, but is definitely noiser. I haven't driven it yet, can't wait to find out if it has more power. I think I'm probably just going to order a couple of the Catco cats since I found them for $30 on ebay.
Old Apr 7, 2004 | 11:25 AM
Mike89GTA's Avatar
Just drove it around the block, definitely doesn't feel right. I'm gonna just get new cats
Old Apr 30, 2004 | 07:57 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
How so? Loss of power or something? I've never heard of ill-effects from doing this (besides emissions and noise!)
Old Apr 30, 2004 | 08:27 AM
Mike89GTA's Avatar
the power curve just seems peakish
Old Apr 30, 2004 | 10:19 AM
breakthelawinaz's Avatar
Car: 88 IrocZ
Engine: 350 Tuned Port
Transmission: 700R4 on its way out....
i guess this is a little late now but i would have checked the ehat shields for the rattle before i just hammered all the honeycomb out of it, thats what mine turned out to be, i found this out AFTER i hollowed it but i was planning to do it anyway...
*eric*
Old Apr 30, 2004 | 10:57 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I just had my dummy cats installed and it ran great until I shut the car off for an hour and a half. Now it idles for crap, is extremely rich (my block learn is 108 and my integrator in 80) and has no power.
It may be coincidence but it happened right after I had them replaced.
Old Apr 30, 2004 | 11:13 PM
onebinky's Avatar
Gutted cats wouldn't have any effect on the engine running stoich.
Check the o2 sensor out. Maybe the shop disconnected it or fried it with a torch. Gutted cat would not have any effect though.
Old Apr 30, 2004 | 11:54 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
i second that. i think its the o2 senser
Old May 1, 2004 | 11:46 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Doesn't the ECM ignore the o2 sensor in open loop?
Old May 2, 2004 | 12:12 AM
onebinky's Avatar
Yes
Old May 12, 2004 | 02:25 PM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
If I have a high flow cat and a gutted cat, which one should I run for the best sound and performance?
Old May 12, 2004 | 03:08 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Shouldn't be a difference, at least noticeable... right?
Old May 12, 2004 | 05:02 PM
LedZep's Avatar
a high flow isnt going to be the same as a gutted cat is it? Whats the deal with turbulence with gutted cats?
Old May 12, 2004 | 09:57 PM
iroc-ice's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
My car also did this when I had it running the exhaust with nothing after the cat. I checked my o2 sensor, it was fine. I put my exhaust back on and the car runs fine again. I think the lack of backpressure from the open exhaust caused the ecm to go crazy. Just my 2 cent.
Ray D.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
