Third Gen Dual Exhaust Picture Collection
#452
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: Third Gen Dual Exhaust Picture Collection
@ ProtoMaster22 -What muffler(s) did you use? It looks like they say Magnaflow. How loud are they? Any drone?
Thanks,
Joe
Thanks,
Joe
#455
Car: 1986 TransAm
Axle/Gears: Mossier axles, 2.73 gears
Ok I'm sorta new to the world of third gens but I'm curious as to what and or where you got all the chassis reinforcement stuff for the underbody of the car? I know these cars are already pretty decent cone killers, but handling is a big part of going fast and I'm pretty sure that's why we're all in this right? I really like the exhaust and will more than likely attempt to copy this setup as mush as possible. Any info is appreciated.
#458
I got my subframe connectors from Spohn. They are one of the top third gen component sites you'll find!
They also have the "wonder bar", springs, A-arms etc. Just about everything you'll need and 99% of it is direct fit. Very little from them needs any work though as with all after market part companies, you'll find the occasional part that doesn't fit quite right.
#459
www.bmrsuspension.com
www.umiperformance.com
www.foundersperformance.com
www.spohn.net
www.paracing.com
www.racecraft.com
just to name a few. there are others available.
www.spohn.net
www.paracing.com
www.racecraft.com
#460
Car: 1986 TransAm
Ok awesome! Those sites are gonna help a lot! Although the crossmember from the site doesn't look like its notched like the one on that IROC, it's just straight, I guess a guy with a little know how and the right equipment could probably figure something out though.
#462
Car: 90 Firebird Formula
Engine: 350 v-8 5.7
I'll try to make a long story short...the Y pipe was cut out on my 90 Formula and a section of the exhaust was missing. In putting the pieces of the puzzle back together, I order a Dynomax dual cat kit from Summit Racing. Is there a special type of hanger that I need for one of the cats? Something's missing...go e-z on this female Forum member...restoring my deceased nephew's 90 Formy as a labor of love and new to the world of 3rd gens!
#463
Engine: 350 v-8 5.7
Found out it needs part #GM 10081609, which is a hanger for the catalytic converter. However, I plug this number in everywhere-Hawks, Summit, Classic Industries, etc., and no one has this. E-mailed GM parts to see if by chance the part # changed...in the meantime, if anyone has a picture of what this part looks like, I'd be very appreciative!
#464
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
http://parts.nalleygmc.com/showAssem...ssembly=380018 at least get you close. you shouldnt need an exact factory part unless you are really set on being perfect. any muffler shop should be able to take care of you.
#465
Engine: 350 v-8 5.7
Thank you for the response. I realize finding this part is like a needle in a haystack unless I can find one used. I have this request under parts wanted but my Plan B is that I would need to get one fabricated. That's why I requested a photo because I have no idea what this looks like to describe it to a muffler shop. Stupid question here, but on that diagram, is it number 11?
#466
I feel like it does matter, the idea behind an X-pipe, is to smooth out the "crowding" caused by cylinder 8 and 4, and 5 and 7, (same bank firing back to back), so if one leg going to the X pipe is longer enough, the crowded pulses may meet at the X instead of one crowd, and one void.
#467
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
its not in the description because its discontinued. notice it jumps from 10 to 12.
#468
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
edit. you may be better off using a 4th gen hanger and having it modified. save you time and money if a shop does it.
http://www.ebay.com/itm/98-02-Camaro-Firebird-Y-pipe-Exhaust-Hanger-/271219378520?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f25ef4958&vxp=mtrdirect fit to the tranny, but not a direct fit to the pipe, but the pipe could be modded to fit the hanger pretty easily, imo.
#469
Engine: 350 v-8 5.7
Gotcha, thanks! I tried ebay and hawks, but by trying to plug in the GM part # I had...I will definitely dig into this further with the info you provided. I really appreciate it!
the hanger is #11. this item shoujld be fairly common on ebay or hawks third gen, house of camaro, etc. perry pam may have something like this. it is a pretty specific piece, but a few bolts and plates and a welder, it can be made.
#470
Engine: 350 v-8 5.7
This info is exactly what I was hoping for
98 02 Camaro Firebird Y Pipe Exhaust Hanger | eBay
#472
Car: 87 IROC
Engine: L31 350
The GM part number does not usually get you anywhere on the aftermarket sites. GMPartsDirect, GMPartsEast, or parts.nalleygmc.com are good options for GM part numbers.
Searching for replacement parts, go by name, such as Google'ing "Camaro catalytic hanger".
Go here for 4th gen replacements... #29 on the trans for $31.53, which connects to #31 on the converter for $26.70.
If you REALLY want original there is this for $100. Or you can get lucky like http://www.ebay.com/itm/NOS-catalytic-converter-exhaust-bracket-hanger-Camaro-Firebird-Z28-Trans-Am-/390655645517?pt=Vintage_Car_Truck_Parts_Accessories&hash=item5af4e4174d&vxp=mtr on ebay for $50.
I'll have to keep these handy for when I work on my Camaro exhaust.
#473
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
Here's my 3" dual with magna-flow x- pipe system with video
#477
Car: 1985 firebird
Thanks guys!
It's an Ed Quay wing, came with struts but I don't use em.
Runs high 10's low 11's depending on 60' at 122.
#486
1 Post
Car: 87 Camaro Z/28
Engine: 327 SBC, 495/481 lift, Dem 625cfm
Transmission: B&M TH350 Stage 2
Axle/Gears: 3.90
375hp 327 sbc bored .030 over, Hedman full length tube headers, 3" collector into 2.25" pipes to an H-pipe just behind the trunk, into 3" Flowmaster Super 44's just under the rear bumper. Future project to cut the floor of the trunk on the passenger side and have the second muffler rotated out of the way like the other one.
Hedmans warped at the flange are being replaced this weekend with hooker ceramic coated shortys because they also rub the chassis on the driver side, with the high lift cam it "bumps" and knocks the car.
#487
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
https://www.youtube.com/watch?v=HOWyMXd7kIA
#492
1 Post
Car: 87 Camaro Z/28
Axle/Gears: 3.90
I've seen the Nelson Camaro, It's just not fair....I'm getting some pics of my true dual exhaust to post on here just so you guys can see what I did. It's been inclement weather the last few days so I haven't been able to take them. Supposed to be nice tomorrow so that's when I'll get them and post them.
#493
Car: firebird 91
Engine: 350 5.7 small block
Transmission: turbo transmission
Here's my setup gotta get some better pics but got dual 2.25 cherry bomb sound a lot quieter and better it was a straight pipe originally but I cut out and welded cherry bomb in place they originally went out the same place but it was just sounded like a old truck now it sounds better.
#494
Car: 1991 Chevy Camaro Z28
Engine: 5.7lt TPI L98
Axle/Gears: Drum Brakes, Not Sure Gears
Ill be getting my exhaust done soon in my 91 z28 TPI i have to leave it stock cats forward for Cali Smog crap but cat back with the dual cats id like to do 2.5 inch pipe with an x pipe just after the cats and im curious if theres a way to get dual 2.5 over the axle in the stock routing?
#497
Was hoping for some pics focusing on the part by the panhard bar seems almost to small of a space for the pipes...
#498
you could always run this...it will provide ample space :
http://www.foundersperformance.com/p...elocation-kit/
#500
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
