big difference in 1 5/8 and 1 3/4 headers?
Hey guys, I currently have hedman long tubes on my car, but was thinking about changing to hooker long tubes. just because they are a little bigger. but is 1 5/8 really that more restrictive than 1 3/4. the hedmans fit great. and I really dont see spending that much more for something that might not help that much. What do you guys think?
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
what kinda cam are you using? the 1 5/8 will probably offer a little extra torque though.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
As long as your header ports line up with the exhaust ports on your heads, with no overlap, with long tubes you are fine.
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Im in the same boat as you are camarokid01 I have the 1 5/8's longs on my 383 I was messing around with the desktop dyno and it appeared to me that the 1 3/4 made the power curve smoother but that could just be the computer messing with me since sometimes it's accurate and other times it is not. I also noticed around a 4-5 hp increase. Anyone else have similar results?
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: big difference in 1 5/8 and 1 3/4 headers?
Car: 88 GTA
Axle/Gears: 3.27 9bolt
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
As a general rule 1 5/8" headers are good up to around 400hp. Above that you definitely want 1 3/4" headers.
LT1Formula
20
Nov 14, 2015 12:02 AM
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
