making 3.4 headers smog-legal
Old Jul 23, 2008 | 11:43 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
I am putting together a 3.1-3.4 swap for my 91 Camaro (200,000+ miles, so time for a change...)
I can run 3.4 headers with the core swap, but I want to put the 3.1 accessories on it as described in the 2.8-3.4 boogie.
1) I assume I need AIR fitted headers, correct?
2) Any problems in compatability between the 3.4 AIR headers and the 3.1 AIR system?
3) Any other issues that anyone has come accross?
Old Jul 23, 2008 | 01:44 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Re: making 3.4 headers smog-legal
I know with my headers they dident have the AIR stuff on them and a local shop welded all the AIR tubes on for like 100$ so that doesent matter much, unless you cant weld and dont want to spend extra money.
Old Jul 23, 2008 | 08:05 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Do you mean headers or exhaust manifolds? If manifolds then just use the one you have. The only headers that will work on these motors are the Pacesetter headers for the 2.8. They are smog legal for the 2.8s but not the 3.1s since the AIR pump won't work without modification or at all.
Old Jul 24, 2008 | 05:01 PM
micktroup's Avatar
Engine: 5.7L V8
Transmission: auto
The 3.4 headers work (same heads) but they do need to be 'massaged' to fit a 3rd gen, since they are designed for the 93-95 Camaro.... I just want it to pass a visual inspection if necessary, since it will be a 93-95 engine in a 91 car.
hectre13
Sep 8, 2015 03:38 PM
LilHot
Aug 23, 2015 09:36 PM
sreZ28
Aug 14, 2015 07:48 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
92projectcamaro
Aug 6, 2015 01:20 PM
