1984 Camaro Sport Coupe 305 exhaust
Car: 1984 Sport Coupe
Did 1984 Camaro sport coupes come from the factory with dual exhaust? And if so, was it the same stock set up that came on a 1984 Z28 with the same base 305 V8? Thanks!
Re: 1984 Camaro Sport Coupe 305 exhaust
Dual exhaust came in about three forms on thirdgens...
An LG4 in a sport coupe would have the exact same exhaust as an LG4 in a Z28. Which is pretty much the same exhaust you'd find on a LO3 TBI V8, lower output LB9 305 TPI cars, and aside from slight change to the Y pipe and different manifolds - most of the V6 cars. L69 HO 305s, most better 305 TPI, and all the 350 cars got higher flow manifolds, better Y-pipe, and a 2.75" intermediate pipe. The exhaust is generally one of the big contributing factors to the difference between the low output and high output engines.
- Y pipe behind the manifolds, into one cat, one pipe to the muffler, two pipes out of the muffler.
- Y pipe behind the manifolds, into one cat, one pipe to about the axle, splitting off into two pipes, each going to a double T arrangement, two mini mufflers and two tail pipes.
- One pipe from each manifold to a pair of cats, then Y-pipe back to one pipe to the single muffler, two pipes out.
Car: 89 Firebird
Engine: 355 TBI
#2 was a great sounding exhaust. That is what came on my 82 Z28 pace car.
5speed88
05-20-2011 04:20 PM
