1987 Power antenna
Old 09-15-2017, 08:20 PM
TwoTimeSC's Avatar
1987 Power antenna
I know this is probably a long shot but I need a complete WORKING power antenna assembly that will fit my 1987 GTA. Needs to have the top end parts with it (Nut, etc.)
I am a new GTA owner so don't yet know all of the interchangeability between years.
If you have one, PM me a price shipped to 35758.
Thanks.
Old 10-08-2017, 10:22 PM
TwoTimeSC's Avatar
Re: 1987 Power antenna
ttt
Old 10-12-2017, 10:00 PM
TA8487's Avatar
Car: 1987 GTA & 1984 Trans Am
Engine: 383 stroker TPI
Thanks.
Yes, they are getting hard to find. I am hesitant to sell my spare since I have a two thirdgens with power antennas, and both have broken in the past 5 years, when the replacement masts were less expensive. I saw a non-working Corvette "repairable" for $159 and the stupid replacement mast for $299 on eBay. Wow....
I will need to test this spare first and let you know.
Old 10-13-2017, 07:46 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Better hang on to it
http://www.ebay.com/itm/POWER-ANTENN...AEKxYQ&vxp=mtr
http://www.ebay.com/itm/POWER-ANTENN...h6pPAA&vxp=mtr
Old 10-13-2017, 09:38 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Don't forget Denny, http://www.thirdgenranch.com/catalog...05f732ba6fc63a
Old 10-13-2017, 09:53 PM
TA8487's Avatar
That eBay link isn’t even the original part so the fitment is not the same.
Old 10-14-2017, 07:04 PM
TwoTimeSC's Avatar
Well, if you do want part with one, just let me know.
Shoot me a PM with a price.
Old 10-15-2017, 03:16 AM
t/aws61985's Avatar
Car: 85-6 TA 85IROC 82-6 MSE 15th/83pace
Engine: Slow ones
Transmission: 700R4/T5
Axle/Gears: Weak ones
http://www.ebay.com/itm/NOS-GM-Delco...lZfTag&vxp=mtr
Here is one still in the NOS box From the 80s.
Old 10-15-2017, 03:02 PM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
He's been trying to sell that for an awful long time...
Old 10-16-2017, 05:52 PM
TwoTimeSC's Avatar
I believe I have scored an original NOS GM antenna for $125 shipped.
A far cry from that one on eBay for $400+.
Old 10-16-2017, 06:26 PM
TA8487's Avatar
Almost the right part. The connector on the end is wrong, but you can swap it out or use 3 blade connectors to attach it to the relay. That connector is pre-1982.
It is also missing the rubber boot to fill the hole in the fender.
But looks good.
Old 10-16-2017, 06:35 PM
TA8487's Avatar
Hopefully, you have the antenna assembly from an old one
Old 10-16-2017, 07:59 PM
TwoTimeSC's Avatar
I still have the original I can swap the connector with and still use the original grommet and RF cable.
This was the closest I could find to a unused original GM unit that was reasonably priced.
If it turns out I can't use it, it will go on eBay for less a lot less than $400+ !
Old 10-16-2017, 08:30 PM
TA8487's Avatar
It should work just fine.
