Power Mirror Motor - Driver Side
Car: 92 Firebird
Engine: 305 V8 (L03)
I'm looking for the electric motor and mounts for the driver side mirror. I need everything that comes inside the housing. I can only find the mirror glass @ online vendors. Any advice? Thanks.
Re: Power Mirror Motor - Driver Side
Post a picture of your power mirror guts if you can..... not all electric mirrors use the same guts. This pic shows 2 different Drivers side power mirrors........... The brace, Lens backing plate, and the mirror power motor are DIFFERENT and not compatible with each other. I THINK the green mirror is 82-85 and I THINK the grey mirror is 86+.
Car: 92 Firebird
This is the way I bought the car, these loose pieces were sitting in the passenger seat so I don't know how many pieces I need total.
Cable harness has been clipped.
Car: 92 Firebird
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Well, somebody did put the mirror switch in there all right, but is there a connector attached to the back of it and a harness leading to the non electric mirror? There's also a rubber tunnel between the door and body for said harness to pass through. Any chance you have that too? Check it out and you'll know better all you would need to convert it
tlman12
05-23-2013 04:21 PM
platanoman31
11-29-2010 09:51 AM
LMSkyliner
Exterior Parts Wanted
02-10-2008 11:11 AM
FastAndFurious
10-27-2001 10:39 AM
