fourth gen coolant tank swap
ok I know this has been done before but I wanted to add mine, its an easy setup and looks great I think! got the template which is a perfect fit! then just aligned it till I got it where it need to be then cut my hole, I had to dril and tap a hole for the bolt that secures the tank.
Re: fourth gen coolant tank swap
Look about right! Nice job.
I had trouble with my one bolt stripping out of the sheet metal. If I were to do it on my current car, I would probably be tack welding a nut on the underside, or using threaded body clips at the least. You might get yours positioned better though...I was flying blind when I did mine the first time haha.
I still like the idea of the dual tanks. Coolant/washer fluid in place of the battery, and sticking the battery somewhere else... but that 4th gen set up is nice and clean!!!
J.
J.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
awesome ill be doing this in a week. where did you get the template for marking/cutting?
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
I definitely plan on doing this soon to my car. Very clean, and my car never sees rain so I will be ditching the washer bottle all together.
Car: Camaro, Denali
Engine: 5.7
Very nice work. here is mine. i wanted my fill neck a little more hidden in the wheel well.
https://youtu.be/ICXWEErXmr0
Car: 1983 Z28
Engine: Forged 355
My 4th gen coolant tank is tucked in the passenger fender, I'll get a picture tomorrow.
Does anyone have pics of the 4th gen washer fluid bottle relocated? If so could you send me some or post pics? I'm concerned of the plastics that are in the nose. If removing will cause over heating issues! Thanks guys!
Chopski (09-04-2022)
For anyone interested, I made a pretty good video on installing a 4th gen Coolant overflow.
https://m.youtube.com/watch?v=zPZHyh3kPNs
dennisbernal91z
Members Camaros
279
02-01-2024 06:51 AM
FueledSoul
Fabrication
69
07-03-2018 07:16 PM
